Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Problem to display mesh in Paraview
Like Tree1Likes
  • 1 Post By dasch
Old   August 9, 2011, 10:16
Default Problem to display mesh in Paraview
Voyage_gui is on a distinguished road
Hi everyone,
thanks in advance for any kinds of help.
Here's my small pb: when i want to visualize my mesh using Paraview, it links automatically in triangular mode the vertices (2D) whereas i would prefer staggered grid.
It s ok on the border of the domain (see picture) but not if i create a slice inside the domain. I can't find the appropriate option. The mesh is cartesian and uniform.
Guillaume
Voyage_gui is offline   Reply With Quote
Old   August 16, 2011, 05:40
No answer for my message in the bottle ?
Thanks
Old   August 16, 2011, 10:21
Daniela
dasch is on a distinguished road
Hi
try to use the filter 'extract cells by region' instead of 'slice' to create your slice.
Daniela
Haces likes this.
dasch is offline   Reply With Quote
Old   August 16, 2011, 10:49
Hi Daniela,
This could be alsmot awesome if i could extract only the plane i chose instead of half a volume (check the pict). I tried to create it directly from a slice but it didn't work out. If you have any idea ...
Thanks a lot in advance
Old   August 18, 2011, 16:30
Ertan Karaismail
ertan is on a distinguished road
In addition to what Daniela suggested, on the 'extract cell by region' panel, select both 'extract on intersected' and 'extract intersected'.
HTH
ertan is offline   Reply With Quote
Old   August 19, 2011, 04:03
Great, thanks a lot Ertan ! I chose last time one of those 2 options independently from the other one without success!
Thanks Daniela too
Guillaume
Mesh is doing some problem prwl120 FLUENT 2 May 21, 2015 14:05
[ICEM] Problem with using the Delaunay volume mesh method manahara ANSYS Meshing & Geometry 12 December 25, 2014 21:54
[ICEM] problem in mesh output mehrzad ANSYS Meshing & Geometry 2 December 10, 2014 18:07
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
