Home > Forums > OpenFOAM Paraview & paraFoam
paraview 3.10.1 reading decomposed data
Old   September 13, 2011, 07:39
Default paraview 3.10.1 reading decomposed data
Stefan
preibie is on a distinguished road
Hallo,
I want to read a decomposed case with paraview. But in the new version 3.10.1 I doesn't have the choice to read a decomposed or reconstructed file.
Have somebody an Idea
Thanks
preibie is offline   Reply With Quote
Old   September 13, 2011, 08:27
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Greetings Stefan,
If you are running ParaView with OpenFOAM 2.0.0/1/x, then run it like this:
paraFoam -builtin
This will make it use the internal reader for OpenFOAM cases, which allows you to open a decomposed case without the need for MPI.
Nonetheless, the internal reader in ParaView 3.10.1 sometimes fails to open certain cases/results that were executed with OpenFOAM 2.0.
If these fail, then the next step would be to run:
reconstructPar
for the decomposed case to be reconstructed.
If you still want to try and open the case with ParaView in parallel mode, see your other thread: http://www.cfd-online.com/Forums/ope...-parallel.html - I'll answer you there shortly!
Best regards,
Bruno
Thread Tools
Trackbacks are On
export data from paraview lions85 OpenFOAM 4 June 2, 2011 13:33
Mesh conversion from Ansys ICEM fabian_korn OpenFOAM Meshing & Mesh Conversion 3 February 24, 2010 09:19
Reading Data from a file Pravir FLUENT 3 February 16, 2003 05:57
Reading data file MON FLUENT 4 September 20, 2002 14:25
reading data from model yusoff CFX 3 March 20, 2001 00:12
