[General] Water surface profile in OpenFoam dambreak case |
January 28, 2012, 23:59 |
abdikerim kurbanaliev
Rep Power: 15 |
Dear all!
Can someone help me with my problem? I need to build 3D water surface profile for OpenFoam dambreak case. The picture should be like as in attached file. How can I do that? Any help will be highly appreciated. Thanks in advance. Last edited by kerim; June 12, 2020 at 17:52. |
January 29, 2012, 13:26 |
Vieri Abolaffio
Rep Power: 16 |
Hi karim.
Assuming you have already run the case, you need to open paraview, load the case, make shure that the VoF is loaded (alpha) and then create a contour of 0,5 alpha. Make shure that it is visualized as a surface and there you go. Hope it helps. |
February 9, 2012, 18:21 |
Rep Power: 15 |
Hi Vieri,
Thank you for your information. I followed to your suggestion but it doesn’t help me. Please see the pictures I received. There are two of them: the first is the alpha surface plot at the end time and the other is the counter plot -isosurface of alpha value 0.5 at the end time. It is not what I am looking for. Any other idea? Kerim Last edited by kerim; June 12, 2020 at 17:52. |
February 20, 2012, 03:52 |
Mattia de\' Michieli Vitturi
Rep Power: 17 |
You should try the "clip" filter for alpha with a value of 0.5.
Mattia |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFoam restarting simulation, stops at first Time loop | syntex | OpenFOAM Running, Solving & CFD | 4 | April 5, 2019 11:20 |
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 | alsdia | OpenFOAM Running, Solving & CFD | 3 | October 22, 2012 11:25 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
