surfaceTransformPoints -rotate
Dear Foarmers
I have a problem with the next command: surfaceTransformPoints I can rotate the stl using surfaceTransformPoints cad.stl cad-r.stl -yawPitchRoll "(0 -5 0)" but if i want to rotate the stl from another point different (0,0,0), example rotate the stl from to (0 2.5 0) how i can do it. Thanks in advanced |
Greetings ynos,You'll have to do it in multiple runs. This is because surfaceTransformPoints (as well as transformPoints)was designed to do basic space transformations, one at a time. Additionally, there is (or at least was) a known bug where for rotating 180 degrees it requires that we do 2 runs of 90 degrees each... or something like that.
So - if I understood you correctly - in your case:
Bruno |
