Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
sample utility surfaceformat as grid data for gnuplot circular crosssection
Old   July 13, 2012, 09:05
Default sample utility surfaceformat as grid data for gnuplot circular crosssection
cfddwarf is on a distinguished road
Hello everyone,
I just got started with using gnuplot as my postprocessing tool in combination with the sample utility. Now I want to creat 3d graphs and contourplots. For this I need to use the function set dgrid3d in order for gnuplot to interpolate between the different values.
My data set is a plane thats the circular cross section of a cylinder. After interpolating, the plots are for squares rather than the original circle. How to do any better?
I got the idea that the data has to be stored in grid data format, in order to not use the dgrid3d option. However its way too many data points to sort this manually..
Any help would be appreciated!!
cfddwarf is offline   Reply With Quote
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
structured and unstructured grids user Main CFD Forum 6 November 25, 2010 01:14
Obtain Geometry Data from a Grid File in CFX 10.0 ARJUN CFX 2 August 17, 2006 07:20
Data Structures for unstructured grid generation Dinesh Godavarty Main CFD Forum 0 December 5, 2000 10:49
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
