Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
select a point through specifying the coordinates
Old   February 4, 2013, 10:26
Question select a point through specifying the coordinates
hz283 is on a distinguished road
Hi All,
I know I should post this in the Paraview's forum, but I think more friends are here.
When I use the filter "plot selection over time", I need to specify a point in the flow fields. In the past I always use the mouse to click on the contour plane. However, this is not very accurate. I would like to select a point through specifying the coordinates. I check the user guide but I did not find a good way to do so. Does anybody know how to do it?
Thank you in advance!
best regards,
H
hz283 is offline   Reply With Quote
Old   February 5, 2013, 02:32
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hey hz,
yo can use the probeLocations utility of OpenFOAM. It's in applications/utilities/postProcessing/sampling/probeLocations
Copy the probesDict to your case folder and change the entries to your need. You can also probe at multiple locations.
Then run probeLocations and some files will appear with the data inside. This data can then be plotted with any common plotting tool (Gnuplot, ...)
Best regards
Kathrin
kathrin_kissling is offline   Reply With Quote
probing vorticity at a point suryawanshi_nitin OpenFOAM 7 May 15, 2014 05:46
[ANSYS Meshing] Importing Cylinders by Point Data Input with Radii EphemeralMemory ANSYS Meshing & Geometry 2 May 31, 2012 13:34
Is it possible to get value of a variable at given coordinates without a point? technocrat CFX 5 March 23, 2010 17:05
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 04:56
[OpenFOAM] Cell Data to Point Data Issues mcintoshjamie ParaView 2 November 19, 2009 03:55
