Sampling fields data from regions (cellZoneSet)
Hi OF comunity,
I am working with OF 2.1.1, and I need to extract values of fields (velocity, pressure, etc) from within regions previously defined. I have created cellZoneSet sets using topoSet, and I am able to visualize the fields values for those defined zones in paraFoam, however I was wondering if it was possible to get that data directly using some OF tool, like sample or something similar. Any help in this regard is very much appreciated. Cheers, |
Hi
Did you find an answer for the SampleDict for Regions. I use chtMultiRegionSimpleFoam. so i have many regions. I tried to use the sample -region But it doesnt seem to work. my region name is Kuhlkoerper. Should i define the region name somewhere in the SampleDict File or is it only required while running from terminal... sample -Kuhlkoerper Kindly Help Thanks & Regards Unni |
hey guys,
you can create one sampleDict file for each Region and copy them into the folder "system/regionname/" After that you can run sample in each region by the command sample -region regionname for example sample -region fluid sample -region solid best regards Sebastian |
Thanks Sebastian.
sampleDict using cloud option along with data file...
Hi
I have to use sampleDict file to sample field varialble T at a set of points in the simulation domain and I am using "cloud" option for Set. Now I am having a data file containing point coordinates, at which data is to be sampled. The problem is how i could specify that points data file in sampleDict file. Quote:
Hi
thanks for your response and I just have done that by writing some script and get a list of cell coordinates and then giving that list to sampleDict... |
