Whatbs the meaning of variables in the computed results |
May 26, 2005, 03:15 |
Hi, All
I'm a new user of Ope
MaJianfeng
Rep Power: 17 |
Hi, All
I'm a new user of OpenFoam. I just found her several days ago and was interested in its open and robust attributes. After plays with it, i think it has a bright promising if it's help documentation can be strengthened. Now, comes my question: I run the LES case:channel395 and get several results written as files in different directory,e.g. in directory 1000, there are files of P,U,u_0,k,.....etc. My exact question is what's the meaning of U_0,Umean,R,Bmean. Does Umean means the average U with time?? Can anybody help me?? |
May 26, 2005, 04:25 |
Umean is a running average of
Gavin Tabor
Rep Power: 17 |
Umean is a running average of the velocity field and R is a running average of the 2nd moments (velocity variance av(u'u'). Bmean is a running average of the SGS stress tensor. By running average I mean a continuously-updated time average of the quantity.
Most of this is in createAverages.H, which is fairly easy to read once you get used to the syntax. I actually can't find where U_0 is being defined : I'm wondering if its redundant. I'll keep looking. Gavin |
May 26, 2005, 05:06 |
U_0 and the other *_0 fields a
Eugene de Villiers
Rep Power: 21 |
U_0 and the other *_0 fields are the old time values (i.e. timestep previous to U). They are necessary to restart calculations that use second order accurate schemes in time like Crank-Nicholson.
For the rest,"p" for a incompressible code is pressure devided by density. For a compressible code it is just the pressure (same for mean quantities). "pPrime2Mean" is the mean of the square of the deviatoric part (p-pMean) of the pressure and is a good indicator for noise. "nuSgs "is the subgrid-scale viscosity and "k" is the SGS turbulent kinetic energy. "nuTilda" is a working SGS viscosity that is only used with the Spalart-allmaras model. Have I missed anything? |
January 29, 2007, 12:55 |
Hello
Does anyone know what
Hello
Does anyone know what is the definition of the 9 components of Reynolds stress R in OpenFOAM? Thanks! |
September 12, 2007, 17:24 |
Hi all,
I was looking at w
kumar
Rep Power: 17 |
Hi all,
I was looking at what the components of R is and how they are calculated in channelOodles. In createAverages.H, R is created as a symmetric tensor. so the 6 components of R written out by the program are Rxx,Rxy,Rxz,Ryy,Ryz and Rzz. As Dr. Tabor remarks above , R represents the variance of velocity thus the components of R should ; Rxx=ave(u'u') , Rxy=ave(u'v') , Rxz=ave(u',w'), Ryy=ave(v'v') , Ryz=ave(v'w') and Rzz=ave(w'w'). so the dimensions of R should be [0 2 -2 0 0 0 0] . But if you look at the output file of R generated by the solver (say channelOodles.C) , then its dimension is [ 0 1 -1 0 0 0 0]. Is this correct? Also in createAverages.H, R is calculated as sqr(U)-sqr(UmeanPtr()) . thus R seems to be a function of velocity squared and should have dimension of m^2/s^2. and can someone tell me how to get u'u' from sqr(U) - sqr(Umean) . It seems to me this should be square(U - Umean) Thanks a lot kumar |
October 15, 2007, 07:59 |
Hi Kumar,
About your last q
hadi tartoussi
Rep Power: 17 |
Hi Kumar,
About your last question i can tell you the following (PLEASE SOMEONE CORRECT ME IF I AM WRONG): -R is a running average of u'u' so R=<u'u'>=<(u-umean)(u-umean)> =<(u-umean)^2> =<u^2> =<u^2> - 2<u.umean> + <umean^2> =<u^2> -2<u>.Umean + Umean^2 =<u^2> -2.Umean^2 + Umean^2 =<u^2> - Umean^2. Cheers, Hadi |
October 15, 2007, 08:01 |
Hi Kumar,
About your last q
hadi tartoussi
Rep Power: 17 |
Hi Kumar,
About your last question i can tell you the following (PLEASE SOMEONE CORRECT ME IF I AM WRONG): -R is a running average of u'u' so R=<u'u'>=<(u-umean)(u-umean)> =<(u-umean)^2> =<u^2-2u.umean+umean^2> =<u^2> - 2<u.umean> + <umean^2> =<u^2> -2<u>.Umean + Umean^2 =<u^2> -2.Umean^2 + Umean^2 =<u^2> - Umean^2. Cheers, Hadi |
June 13, 2010, 22:46 |
Jiang
Rep Power: 16 |
Very good!
Thanks for engene, kumar and hadi's explanation. hadi's explanation is especially excellent. This thread shouldn't be forgot. |
November 12, 2012, 01:52 |
#9 |
Aru
Rep Power: 14 |
If it is necessary only for restarting calculations, why we have to store this data? I am doing LES and is experiencing difficulty with disk space. If I dont save this *_0 fields, I can save about 10 GB space. Would you recommend removing these fields?
How WHF is computed by Fluent ? | cfdltt | FLUENT | 0 | January 24, 2008 10:46 |
[OpenFOAM] Whatbs the best way to visualize paticles from lagrangian solvers | sek | ParaView | 2 | September 19, 2007 17:02 |
pressure is not only computed | KtoTo | Siemens | 0 | March 5, 2007 11:09 |
Whatbs best way to create new case | jvn | OpenFOAM Pre-Processing | 2 | June 20, 2005 21:19 |
how can i put the computed data into simulation ? | cornerstone | Main CFD Forum | 4 | October 3, 2002 19:39 |
