-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Area/Mass weighted average at any arbitrary location (http://www.cfd-online.com/Forums/openfoam-post-processing/107293-area-mass-weighted-average-any-arbitrary-location.html)
aship September 23, 2012 05:51
Hello all,
I am trying to calculate area weighted average of velocity and pressure at any given time and arbitrary location. I was not able to find any utility for doing it. I saw this link
http://openfoamwiki.net/index.php/Co...unctionObjects
but to use it you need to know the name of patches (which i only know for the boundary patches (eg inlet outlet). What if I want it at centre of my grid?. I have to do it for lots of time interval so using parafoam integration function is also not efficient.
Currently I calculate it using matlab by taking sample points at that location. But it will be very helpful if someone can highlight a method so that it can be done directly from open foam.
Thanks & Regards
gschaider September 23, 2012 10:18
Originally Posted by aship (Post 383186)
Hello all,
Thanks & Regards
http://openfoamwiki.net/index.php/Contrib/swak4Foam of which the simpleFunctionObjects are now a part has a functionObject that allows arbitrary calculations on sampledSurfaces (I think that is what you mean with "arbitrary location"). There is also the possibility to do it on faceSets/Zones which is computationally less expensive (but you've got to add the sets/zones) during preprocessing
aship September 23, 2012 12:26
Thanks for your reply..but i couldn't understand your suggestion...simplefunctionobject has utility named patchaverage by which i can do this area weighted calculation but the problem is that we have to give the name of patch to it (which is only available for boundaries)...let us say i have a channel flow so i will have patches named inlet, outlet, top wall, bottom wall but how about if i want to calculate area weight average at centre of channel (i dnt know the patch name here), i tried to create a interior boundary in mesh formation in gambit and named it there as x=0.5 but when i convert it into openfoam format it is just treated it as internal patch and doesnt differentiate it or list it in the boundary file...
gschaider September 23, 2012 18:05
The you're in the faceSet/faceZone-scenario. These two things are the nearest thing to a "internal boundary" OpenFOAM has. Have a look in the polyMesh-directory of the case. Either you have file called fileZones or a directory sets with a file in it that is named like your internal boundary. t depends a bit on the converter you used to create the mesh because with one of them you need to and option (I think -writeZones) to write the faceZones
And on these faceZones or faceSets swak can do calculations like the mass flow.
SirWombat September 24, 2012 05:05
Are you looking for probeLocations? There is a post-processing tool that need a probesDict in the system folder, but you can also use it during runtime by adding this to your controlDict:
functions (
        probes {
                type probes;
                functionObjectLibs ("libsampling.so");
                fields (
                        p_rgh
                        U
                probeLocations (
                        (1.0 0 0)
                        (1.5 0 0)
                        (2.0 0 0)
                        (1.0 0 0.5)
                        (1.5 0 1.0)
                        (2.0 0 1.5)
                outputControl timeStep;
                outputInterval 10;
it will create a folder called "probes" with the interpolated values of the fields "U" and "p_rgh" at the six probe locations (I'm using interFoam here). The probe locations are defined as (Xposition Yposition Zposition).
You can then plot those using gnuplot, i.e. by the command "gnuplot --persist" (persist to keep the window open after plotting)
set xlabel 'time [s]'
 set ylabel 'pressure [Pa]'
 plot 'probes/0/p_rgh' u 1:2 t '1st probe location' w lines,\
 'probes/0/p_rgh' u 1:3 t '2nd probe location' w lines,\
 'probes/0/p_rgh' u 1:4 t '3rd probe location' w lines,\
 'probes/0/p_rgh' u 1:5 t '1st probe location' w lines
Its plotting the pressure vs time from the file "probes/0/p_rgh"
Is that what you wanted?
Greetings Jan
gschaider September 24, 2012 13:27
<snip>
Greetings Jan
The original posting started with "I am trying to calculate area weighted average" so I think probes are not the solution here.
aship September 24, 2012 14:14
i dont think probesDict will serve the purpose as it gives the values of U and P at a particular point over the time...I get that along a plane/line (in 2d) using sampleDict...i want to perform calculations like patchaverage along a line/plane...problem is i dont know how to reference a patch which is not a boundary
@Gschaider I didnt see any directory named files zone or any other which contains the information of the line/plane i defined in gambit...i used fluentMesh2foam command....
gschaider September 24, 2012 14:30
That one needs to be "pushed" with an option to generate them. The -h-option is your friend. Call
fluentMeshToFoam -h
and pick an option that you like
aship September 26, 2012 05:51
It didnt work I named two lines in gambit with a boundary type interior and then i used fluentMeshToFoam -writeSets and also fluentMeshToFoam -writeZones but I couldnt find anything in the set folder that could be used to reference in patchAverage utility also the facezones and cellzones file were empty
gschaider September 26, 2012 06:06
patchAverage can't work with zones or sets anyway. You'll have to go for the swakExpression-functionObject
The zones-files are there but empty? Strange
Have you tried the "other" fluent-converter?
aship September 26, 2012 06:41
Building boundary and internal patches.
Creating patch 0 for zone: 3 start: 1 end: 100 type: pressure-outlet name: pressure_outlet.4
Creating patch 1 for zone: 4 start: 101 end: 400 type: axis name: axis.3
Creating patch 2 for zone: 5 start: 401 end: 500 type: velocity-inlet name: velocity_inlet.2
Creating patch 3 for zone: 6 start: 501 end: 800 type: wall name: wall
Creating patch 4 for zone: 8 start: 801 end: 60400 type: interior name: default-interior
Creating patch for front and back planes
Adding new patch pressure_outlet.4 of type patch as patch 0
Adding new patch axis.3 of type symmetryPlane as patch 1
Adding new patch velocity_inlet.2 of type patch as patch 2
Adding new patch wall of type wall as patch 3
Patch default-interior is internal to the mesh and is not being added to the boundary.
Adding new patch frontAndBackPlanes of type empty as patch 4
this is what i get when i run fluentMeshToFoam -writeZones
and when i run writesets there is a folder named sets in which u have the boundary files and default interior file (but no file abt the dummy lines i made)
the facezones file reads like this
FoamFile
version 2.0;
format ascii;
class regIOobject;
location "constant/polyMesh";
object faceZones;
0
I am sorry but i dnt know any other converter which can convert a .msh file into openfoam format
gschaider September 26, 2012 07:02
FoamFile
version 2.0;
format ascii;
class regIOobject;
object faceZones;
0
The name of the "other" converter is fluent3DMeshToFoam (the tab-completion of the shell is your friend)
Check whether your interior boundary is actually in the mesh. Either have a look at the end of the msh-file (as far as I remember the boundaries are listed there) or grep for the name you gave it
Luchini January 13, 2015 15:25
I am also trying to do computations on planes inside the domain.
But i have some difficulties on creating the faceSets/Zones required.
According to you which is the best way to create 10 of such arbitrary planes?
Thank you a lot
