Home > Forums > OpenFOAM Post-Processing
ParaFoam Cyclic Boundaries
Old   October 12, 2012, 07:54
Default ParaFoam Cyclic Boundaries
Soeren
Atoom is on a distinguished road
Hi Everyone,
I just startet using OpenFoam for a 2-D case and it works pretty well. For the postprocessing I am using Paraview (parafoam) which also works good - unless I am setting up cycling boundary conditions. I already searched this Forum and found people with identical problems, but no solution which worked for me. The only hint I got is that the order of the boundaries is wrong - but what is the correct order? I tried to use createPatch but this did not work for me as well.
The mesh is generated in Gmsh and is basicly a square with two ripples at the bottom.
Thank you for your help!
Atoom is offline   Reply With Quote
Thread Tools
Trackbacks are On
mapFields - Changing from turbulentInlet/outlet boundaries to cyclic boundaries TianC OpenFOAM Mesh Utilities 8 January 16, 2013 06:15
Parallel refineMesh with Cyclic Boundaries mchurchf OpenFOAM 6 June 20, 2012 13:06
Problems with cyclic boundaries in faMeshDefinition and surfactantFoam safre OpenFOAM 3 December 12, 2011 08:56
ParaFoam canbt handle cyclic boundaries in channelOodles lakeat OpenFOAM Bugs 1 July 17, 2008 12:58
Cyclic Boundaries -> Match Option -> Arbitrary Derek CD-adapco 1 August 4, 2004 22:06
