Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Post process fsi parallel case with foam-extend4.0
Old   September 25, 2018, 04:25
Default Post process fsi parallel case with foam-extend4.0
paulbr is on a distinguished road
I recently manage to make the fsifoam tutorials work on parallel with foam-extend/4.0 (3Dtube and beamInCrossFlow). When using the command reconstructPar, the fluid results are well assembled according to the time step. Yet, the command doest not seem to take into account the solid results.
I've found that foam-extend3.2 has a function reconstructParFsi. Is there, by any chance, an easy way/a function that can do the trick on foam-extend/4.0 ?
Any help is appreciated,
Regards
PS: I'm a new user of foam-extend and this is my first post on this forum. Please, be indulgent, I might have done some stupid remarks or else..
paulbr is offline   Reply With Quote
Old   January 13, 2019, 19:35
Stephen Waite
Stephen Waite is on a distinguished road
with foam-extended 4.0, run
reconstructPar
This will do the fluid files as you mentioned, then run
reconstructPar -region solid
to do the solid region. There is probably a way to do it in one line but I haven't figured it out yet.
Stephen Waite is offline   Reply With Quote
Old   January 25, 2019, 09:39
Hi Stephen,
Thanks for you answer. I don't know why exactly but running reconstructPar then reconstructPar -region solid doesn't do the trick for me...
It gives me this error:
--> FOAM FATAL IO ERROR:
cannot open file
file: /gpfs1/home/2016014/pbrous01/foam/pbrous01-4.0/applications/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid/454361/fluid/10/solid/meshPhi at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 60.
FOAM exiting
This is kind of obvious because there is no "solid" folder in any time repertory given by reconstructPart. I don't know why it gives this error only for the 10th folder though...
Note that 10s is my last time step.
However, I found another way to do this, thanks to Mr. Kristen Rege and this thread:
https://www.cfd-online.com/Forums/op...extend-15.html
This works fine, when it is run in the case repertory:
#!/bin/bash
mkdir tmp
cd fluid
for proc in processor*; do
mkdir ../tmp/$proc
for time in $proc/*; do
ln -s ../../fluid/$time/solid ../tmp/$time
done
done
ln -s ../solid/system ../tmp/system
ln -s ../solid/constant ../tmp/constant
ln -s ../solid/0 ../tmp/0
cd ../tmp
Regards,
Paul
foam extend 4.0, fsi, post process
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 5 June 22, 2019 02:56
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 04:14
