Using probe function or sample utility on a patch
Old   October 19, 2012, 06:47
Default Using probe function or sample utility on a patch
hfs
hfs is on a distinguished road
I am doing a comparison between wind tunnel results and OpenFOAM simulation. Available from wind tunnel are the pressure coefficients (Cp) on 32 points (using pressure measuring instruments attached to the body). The coordinates of those points are available. I need to get P & k fields on the body patch at those 32 points using OpenFOAM.
in probe function & sample utility do not ask for the patch at which I want my results.
http://web.student.chalmers.se/group...ngLucchini.pdf
I mean, the coordinates of a point may not guarantee that It belongs to the patch (due to lack of accuracy of snappyHexMesh). How can get my results at the patch using points' coordinates (to find the closest point at the patch to the point with given coordinates)?
Is there any other function/tool to do the job?
Thanks!
hfs is offline   Reply With Quote
Old   January 27, 2019, 03:49
Default Use patchProbes function
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
In newer versions of OpenFOAM, you can use the patchProbes function objects to extract any patch values.
Usage:
https://www.openfoam.com/documentati...8H_source.html
Best regards,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 6 November 15, 2014 18:04
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 11:56
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
