Home > Forums > OpenFOAM Post-Processing
Unsteady Sample Patchs visualization
Old   December 13, 2012, 12:34
Default Unsteady Sample Patchs visualization
Julien
Djub is on a distinguished road
Hi!
I am using the sample function on a patch, but I don't which is the best file format:
controlDict
functions
{p_Building    {
        type surfaces;
        functionObjectLibs ("libsampling.so");
        enabled         true;
        outputControl   timeStep;
        interpolationScheme cellPoint;
        surfaceFormat vtk;    //    or foamfile
        fields        (      p        );
        surfaces        (
            P_build            {
                type            patch;
                patches         ( Building_patch0 );
                interpolate     true;
My wish is to visualize the results with paraView.
I tried foamFile , but was not able to open it with paraView.
I tried vtk, but paraView can open only one vtk-file (only one time step).
If I rename each file with an index, and put them together in a unique folder, paraView opens the whole as a "movie". BUT it loses the time information (it references the different time steps as indexes, not in seconds). Thus this solution is not convenient (I have to rename each file carefully, and then move it), and not 100% efficient (time disappeared).
Does anybody has a suggestion to solve this problem?
Djub is offline   Reply With Quote
Old   January 21, 2013, 06:01
Julien
Hi Everybody!
Finally, I wrote a script that change the location and the name of each VTK file. For instance:
/0.1246/P_build.vtk
is moved to
/P_build_125.vtk
So, all the time step are compiled in a unique folder with a unique name format: ParaView is able to understand it and can make a movie. Nevertheless, the "time" decomes only an index.
About this index: I had to choose to work with miliseconds, because paraview needs an integer (/P_build_124.6.vtk is not recognized by paraview to be linked with /P_build_131.4.vtk ). So my solution is not perfect! If anybody has a better idea...
Thread Tools
Trackbacks are On
Sample issues MikePo OpenFOAM Post-Processing 1 February 7, 2010 20:20
heat conducting in a solid domain Rogerio Fernandes Brito NUMECA 0 March 18, 2008 18:24
heat conducting in a solid domain Rogerio Fernandes Brito Phoenics 0 March 18, 2008 18:23
heat conducting in a solid domain Rogerio Fernandes Brito CD-adapco 0 March 18, 2008 18:23
about my old post Rogerio Fernandes Brito CFX 1 February 8, 2008 20:19
