Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Forces to be written in different patches
Like Tree1Likes
  • 1 Post By tomf
Old   January 29, 2013, 11:16
Default Forces to be written in different patches
Sha Huang
Joanna Huang is on a distinguished road
Hi Foamers:
I am calculating the forces of a train.stl cases, it contains different patches like bogie, pantagraph, coach body, etc. I want to export the forces of different patches, so I write all the patches in the forces function file, but it does not work, the forces.dat file are alway the total forces, Can anyone help me with this, Thank you so much for that.
Joanna Huang is offline   Reply With Quote
Old   January 29, 2013, 11:27
Sha Huang
the OF version i used is v2.1.1
Old   January 30, 2013, 04:33
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Joanna,
You can get multiple versions of the forces by just making more forces entries in the controlDict. The example below gives you different folders, in this case:
Total, Body, pantagraph. Of course you have to put in the correct patch names for all the different parts.
    Total //name of output folder
    {      type forces;
            functionObjectLibs ("libforces.so");
            patches //includes the contributions of these patches
               Patch1 Patch2 Patch3
            rhoName         rhoInf;
            pName             p;
            rhoInf          1.225;
            CofR            (0 0 0);
            outputControl   timeStep;
            outputInterval  1;
    pantagraph //name of output folder
    {      type forces;
               pantagraph
            rhoName         rhoInf;
            pName             p;
            rhoInf          1.225;
            CofR            (0 0 0);
            outputInterval  1;
    Body //name of output folder
    {      type forces;
               coachBody
            rhoName         rhoInf;
            pName             p;
            rhoInf          1.225;
            CofR            (0 0 0);
            outputInterval  1;
Regards,
Tom
FrankFlow likes this.
Last edited by tomf; January 30, 2013 at 04:36. Reason: improved typestting layout
tomf is offline   Reply With Quote
Old   January 30, 2013, 05:20
Sha Huang
Hi Tom:
Thank you so much for that. I will try that.
Old   February 4, 2013, 10:44
stephane sanchi
openfoam_user is on a distinguished road
Hi Joanna,
can you upload some pictures (mesh, pressure contours, streamlines, ...) of your work about train aerodynamics ?
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Forces on multiple patches in InterDyMFoam Claudio OpenFOAM Post-Processing 5 October 20, 2016 12:46
Forces for airfoil test case Martin_ OpenFOAM Running, Solving & CFD 1 July 2, 2012 11:58
Forces printout for multiple patches ozzythewise OpenFOAM Pre-Processing 3 March 7, 2012 12:59
FORCES don't run! C12Carbon OpenFOAM 0 September 10, 2011 07:34
[snappyHexMesh] SnappyHexMesh large number of patches written prapanj OpenFOAM Meshing & Mesh Conversion 0 July 15, 2009 08:11
