Force Coeffs with icoFoam
Like Tree1Likes
  • 1 Post By A.Wendy
Old   February 18, 2013, 10:33
Default Force Coeffs with icoFoam
VS
VSass is on a distinguished road
Hello there,
i'm trying to use the function object forces and forceCoeffs with icoFoam.
i put this in controlDict :
functionObjects
forces
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (Upstream); // change to your patch name
rhoInf 1.225; //Reference density for fluid
CofR (0.25 0 0); //Origin for moment calculations
forceCoeffs
type forceCoeffs;
patches (Upstream); //change to your patch name
rhoInf 1.225;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0.25 0 0);
magUInf 10.0;
lRef 1;
Aref 1;
I thought that a .dat file should appear in my case directory, but nothing happens.
Is there anything else i should do, complie or add something else?
VSass is offline   Reply With Quote
Old   February 19, 2013, 02:40
Andreas Wendy
A.Wendy is on a distinguished road
hi,
under your case folder should a folder called "forces" appear where the forces file is stored.
best wishes
Andy
A.Wendy is offline   Reply With Quote
Old   February 19, 2013, 05:38
VS
That's the problem, nothing appears. That's why i wonder if i should do some compile or any other form of "activation".
Thanks for the reply
Old   February 19, 2013, 05:42
Andreas Wendy
could you post your controlDict and the boundary file?
Old   February 19, 2013, 05:45
VS
controlDict
| \\ / O peration | Version: 2.1.1 |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application icoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.5;
deltaT 0.0001;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 0.5;
functionObjects
forces
type forces;
forceCoeffs
type forceCoeffs;
rhoInf 1.225;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
magUInf 10.0;
lRef 1;
Aref 1;
U boundary
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (20 0 0);
boundaryField
Downstream
type fixedValue;
value uniform (0 0 0);
Farfield
type inletOutlet;
inletValue uniform (20 0 0);
value uniform (20 0 0);
Upstream
type fixedValue;
Old   February 19, 2013, 05:48
Andreas Wendy
try to put the patch name in your control dict in brackets like:
patches ("Upstream");
regards
Andy
Old   February 19, 2013, 06:28
VS
Nothing happens.It just writes down the timesteps folder with u and p but nowhere the forces.
Thanks anyway Andrew, honestly.
Old   February 19, 2013, 06:38
Andreas Wendy
try the following:
forces
type forces;
outputControl timeStep;
outputInterval 1;
patches ("Upstream"); // change to your patch name
pName p;
UName U;
rhoName rhoInf;
log true;
forceCoeffs
type forceCoeffs;
outputInterval 1;
patches ("Upstream"); //change to your patch name
pName p;
UName U;
rhoName rhoInf;
rhoInf 1.225;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
magUInf 10.0;
lRef 1;
Aref 1;
log true;
i am not sure of the coefficient stuff but the forces should work
jiaojiao likes this.
Old   February 19, 2013, 07:10
VS
Nothing again. I'll give it a shot again later.
Thanks again
Old   February 19, 2013, 07:11
Andreas Wendy
strange. can you upload the complete case folder?
i am stuck at another problem and need something new in mind^^
Old   February 5, 2016, 16:26
Murtaza Abbas
MurtazaAbbas is on a distinguished road
I'm having a similar problem using OpenFOAM 3.0.1. Have you managed to find a solution to as why there is no output postProcessing directory?
Thanks in advance!
MurtazaAbbas is offline   Reply With Quote
force, forcecoeffs, forces, functionobjects
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
How to add a source term (body force) to icoFoam? chris Liu OpenFOAM Programming & Development 4 October 27, 2014 15:38
Force coeffs in compressible flows nachettito OpenFOAM Post-Processing 0 August 13, 2012 06:18
Force can not converge colopolo CFX 13 October 4, 2011 22:03
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
