Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Plotting sampleDict values and problems with probeLocations format
Old   March 23, 2016, 06:24
Default Plotting sampleDict values and problems with probeLocations format
ArielJ
arieljeds is on a distinguished road
Hi everyone,
I have been using probes and probeLocations for some time and getting the data into a csv file using pyFoam:
pyFoamTimelinePlot.py --fields=<field> --basic-mode=lines --csv-file=<field>.csv postProcessing/
And had no issues with it for a while. I attempted to do the same as I usually do (run foamCalc on various fields, then run probeLocations, and then run pyFoamTimelinePlot.py) but am not getting an error from PyFoamTimelinePlot that the files in postProcessing/probes are the wrong format. I've attached my sampleDict file as a txt file and an example of one of my files created after running the probeLocation utility. I noticed that in a previous example that worked, I didn't have the lines at the top listing the probe numbers and locations.
I have no idea why I would have it this time... am totally stumped on this!!
I tried to work around it by using the sample utility but this creates a new directory for every time step. How would I combine that data from all of the time steps into one file so I can plot over time?
I would really appreciate any help on using these utilities, totally confused because I did have this all working well.
arieljeds is offline   Reply With Quote
Old   May 17, 2016, 12:37
gned
gned is on a distinguished road
Issue solved, Ariel, finally?How?
gned is offline   Reply With Quote
Old   May 17, 2016, 12:40
ArielJ
Hi there @gned,
Which version of openfoam are you using?
I discovered that the format that the data for probeLocations is written changes in (I think) version 2.4.0, which makes pyFoamTimelinePlot not work. I resolved this by simply using the source code from an older version (OF 2.3.0) to write the data using probeLocations and then pyFoamTimeLinePlot worked again!
A little bit of a cheating fix, but it worked for me
Hope that helps,
Ariel
post processing, probedict, pyfoam, pyfoamtimelineplot.py, sample
Convergence problems using extreme coefficient values like 1e-16 with porous jump recepky FLUENT 3 November 11, 2017 02:12
Polyflow : Fibre drawing, Problems when viscosity recheaches high values (about 1e14) michael.jeunehomme@gmail. ANSYS 0 August 13, 2015 06:13
Problems with the values of "OBJFUNC_SCALE" Fang-SIAMM SU2 1 April 11, 2013 13:27
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong jannnesss CFX 5 February 25, 2011 16:24
Values of k and e for multiphase problems!! zack FLUENT 0 January 28, 2006 02:16
