[OpenFOAM] Regarding surface tracking in OpenFOAM |
March 8, 2013, 07:14 |
Harshawardhan
Rep Power: 13 |
hello friends,
I want track inter phase in OpenFOAM means I want find out how the alpha(phase fraction) changes at interphase between two fluids . How should I do this???? Please help me Regards Harshawardhan Kulkarni |
March 9, 2013, 10:25 |
Michiel
Rep Power: 15 |
If you use paraview for post-processing you can very easily just plot the alpha1 field and find out where the boundary between 0 and 1 is.
If you want to just track alpha1=0.5 for example you could also sample it. |
March 11, 2013, 04:11 |
#3 | |
Harshawardhan
Rep Power: 13 |
thanks for quick reply.... Can you tell me....... I have to used "plot data "or "Plot over line" in a filter in paraview........And if I used "plot data" and plot generated after that how I can extract that data in a column wise manner so that we can use the information for further processing . |
March 11, 2013, 17:37 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Harshawardhan: Quote:
Best regards, Bruno
March 12, 2013, 06:38 |
#5 | |
Harshawardhan
Rep Power: 13 |
hello here I'm attaching the Image, I want track the interface. I have captured that image at 25th sec. at that time I want to find out all the coordinate at interface separating two fluid. Red: oil blue : air and there is line or curve (white) separating them means want to fine out coordinates of all the alpha (0<alpha<1) reply asap Regards Harshawardhan |
March 14, 2013, 10:29 |
Michiel
Rep Power: 15 |
First of all: you have a value of alpha1 large than 1 in your domain. This is obviously unphysical so I suggest you look into the 'limit' you use for your contact angle BC (i recommend limit gradient)
Second I think you it would help you a lot to look into the documentation of Paraview a bit to figure out yourself what you can do. |
March 20, 2013, 06:25 |
why alpha value exceeds 1
vinita
Rep Power: 13 |
Hello everyone,
I am solving a multiphase case using interfoam. but during solving my alpha value exceeds 1 . how should i limit alpha value within 0 to 1 interval . what is the exact reason of it to increase beyond 1 or decrease beyond 0 .?? plz Help |
March 21, 2013, 12:01 |
#8 | |
Harshawardhan
Rep Power: 13 |
Use Rescale to Data range the path is Display-> (in front) of color by at initially before the play for alpha |
post processing |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
how to generate the STL surface in snappyHex mesh tutorial in OpenFOAM manual | Teemo | OpenFOAM | 5 | June 6, 2016 06:58 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message | peteryuan | OpenFOAM Installation | 6 | August 18, 2013 18:00 |
[OpenFOAM] ParaView ErrOr | soheil nazmdeh | ParaView | 1 | August 17, 2013 07:40 |
