sample error depending on the name of sampleDict element
==1== Just wondering. ==2== When the below command is executed for an arbitrary case Code:
sample -latestTime Code:
1D Code:
--> FOAM FATAL IO ERROR: When I change the name of the sampleDict element from "1D" to "downstream1D", the code can be executed. Code:
downstream1D I only wonder the reasoning behind this if you like. Many thanks in advance. Kind regards. |
