tecplot interrupt when post processing OpenFoam data |
April 3, 2013, 15:10 |
Ye Zhang
Rep Power: 16 |
Dear all,
After finish simulation, when I export OpenFOAM data to tecplot360 2011R2, and it is OK when doing processing like draw streamlines, but it will interrupt when I choose Vector, and click OK when choose U,V variables, and tecplot quit suddenly. Do you know what is the reason? Hope you can help me! Best regards, Ye |
April 3, 2013, 20:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ye,
Quick question: are you importing the OpenFOAM case directly in Tecplot or did you first use foamToTecplot360 to convert the results? Best regards, Bruno
April 6, 2013, 06:18 |
Ye Zhang
Rep Power: 16 |
Hi, Bruno.
Thank you for your reply, I directly import OpenFOAM data to tecplot, because I think there is a import option for OpenFOAM in tecplot360 2011R2. Do I also need to use foamToTecplot360 command? Regards, Ye |
April 6, 2013, 07:20 |
Bruno Santos
Rep Power: 128 |
Hi Ye,
OK, if the problem is in Tecplot itself, then you better contact their support . And/or try upgrading the Tecplot version. I've searched a bit and found this thread: http://www.cfd-online.com/Forums/ope...valuation.html - if you have trouble contacting the support line at Tecplot's website, you can try contacting the forum member scott_rumage directly, because this is the member that seems to be a good point of contact from Tecplot here on the forum. Good luck! Best regards, Bruno
Display Modes | |
[OpenFOAM] is parallel processing available in parafoam for post processing? | sachinlb | ParaView | 1 | August 14, 2012 10:52 |
post process to get an arbitrary face data | oniboy | Siemens | 2 | February 28, 2008 23:12 |
fluent case n data files not exporting to tecplot | krishna | FLUENT | 2 | February 18, 2007 00:24 |
vertex post data | george | Siemens | 1 | January 6, 2007 15:31 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
