-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   In which coordinates system is expressed velocity (http://www.cfd-online.com/Forums/openfoam-post-processing/116064-coordinates-system-expressed-velocity.html)
malaboss April 12, 2013 04:39
Hi FOAMers !
I am currently working on a cylinder and trying to optimize the mesh in the domain that contains the cylinder.
I would like to minimize the error due to "mesh alignment". For that, I need to have the velocity on each cell and the coordinates of the center of each cell.
I made my mesh with the blockMesh utility.
In the file U in each temporal folder, I can see that I have the velocity vector expressed in a coordinates system.
My first question is : in which coordinate system is it expressed ? : Is it the local coordinate system of the cell ? Or every cell of each block defined in blockmesh dict has the same coordinate system ?
This is a problem for me since I have some edges which are curved. Then the coordinate system of each cell with rotate from the reference defined for a block in blockMeshDict.
I can give you more details if you need it
mturcios777 April 12, 2013 12:19
Velocity is always expressed in the global coordinates system.
malaboss April 18, 2013 06:00
Thanks a lot !
