[Sponsors] | |||||
Rep Power: 2 ![]() |
I am using OF-2.0.1. I am trying to validate my solver. the case is supersonic flow over a moving cylinder inside a closed domain. I have got the shock captured well and my density, mach no.. profiles are matching well wrt pattern. Not able to capture the peaks correctly. When I looked closely into the data files, I found that there may not be enough data points close to the shock. Otherwise, the simulation matches well with actual result. Now, what i want to know is how to specify (interpolation scheme) in sampleDict file so that i can have more data points close to the shock (shock position is known wrt cylinder). quick reply would be very helpful - achyutan |
I hope i have posted under the appropriate sub-forum this time..
I am waiting for some help ! - achyutan |
unfortunate that no one has yet posted any reply for this ! I am waiting for some help.. - achyutan |
Jose Rey
Rep Power: 6 ![]() |
Hi Achy,
Are you interested in increasing the interpolation points inside a volume, on a plane, or surface? Are you open to increasing the mesh resolution in that area/volume? Please post your current sampleDict using the [ code] [ /code] tags (without the space) so that it is readable. |
I want to have more interpolation points on a plane capturing the shock. i realize better mesh resolution is one option but i do not want to run the case again. is there any provision in sample dict. I have attached my sample Dict. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| No layers in a small gap | bobburnquist | OpenFOAM Native Meshers: snappyHexMesh and Others | 2 | November 25, 2012 08:54 |
| Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Native Meshers: snappyHexMesh and Others | 8 | September 13, 2012 09:28 |
| .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Native Meshers: snappyHexMesh and Others | 19 | August 4, 2012 07:34 |
| [DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? | ANT | ANSYS Meshing & Geometry | 2 | July 23, 2012 15:25 |
| BlockMeshmergePatchPairs | hjasak | OpenFOAM Native Meshers: blockMesh | 11 | August 15, 2008 07:36 |
