Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
which program is suitable for showing different graphs into one to compare?
Like Tree1Likes
  • 1 Post By Phicau
Old   April 23, 2013, 13:06
Default which program is suitable for showing different graphs into one to compare?
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
1)which software do you suggest for drawing multiple graphs together into one diagram for comparing results?
2)which software is there for drawing graphs other than gnuplot( a graphical software)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   April 23, 2013, 13:27
Pablo Higuera
Phicau is on a distinguished road
Hi
two alternatives are Octave and python (matplotlib). Both of them are very powerful and they resemble Matlab.
immortality likes this.
Phicau is offline   Reply With Quote
Old   April 24, 2013, 14:45
Ehsan
thanks Pablo.
I downloaded Gnu octave and qt octave(does it work based on Gnu octave?)
I couldn't find a good help for octave.do you know?
matplotlib doesn't have a graphical environment like QT Octave?
thank you.
Old   April 25, 2013, 04:11
Pablo Higuera
Hi
You have another option, Matlab, although it is not open source and free.
I have never used Octave, I only know that it exists, and that apparently it is very similar to Matlab. I have searched a bit and found a tutorial which seems quite comprehensive to start:
http://krchowdhary.com/research-meth...matlab-tut.pdf
Regarding matplotlib, this one I have worked with it, and it is also similar to Matlab, only lacking the work environment. However, you can use it along with any python IDE so that you can even track the values of variables at any time. I use it with spyder, for example.
In both cases you will have to script to obtain your graphs, so if you don't know python I would recommend you to start with Octave.
Best
Pablo
Old   April 26, 2013, 23:22
Ehsan
thank you very much.
Is openoffice calc suitable for drawing fipures that can be used in presentations or articles?or is poor in its view.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
