[swak4Foam] what does this swak function of average on average mean?
Like Tree1Likes
  • 1 Post By artymk4
Old   May 2, 2013, 15:12
Default what does this swak function of average on average mean?
immortality's Avatar
Ehsan
immortality is on a distinguished road
I've found this function in an thesis.is it correct?
because it has defined an average of total pressure on the patch at each time step and in accumulations it uses average again.what does average do in this case?is it a correct method to get average on a patch?
Total-pressuresec9outlet
functionObjectLibs("libsimpleSwakFunctionObjects.so”);
type swak Expression ;
outputControl outputTime ;
valueType faceZone ;
zoneName sec9 outlet ;
expression ”sum((0.5∗rho*pow(mag(U),2)+p)∗(area()∗rho))/(sum(area()∗rho))”;
accumulations
average
verbose true ;
autoInterpolate true ;
warnAutoInterpolate false ;
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 2, 2013, 22:16
Retired Super Moderator
Bruno Santos
Hi Ehsan,
Mmm... after thinking a bit about this, I think I can explain what happened:
  1. The current accumulation in your example only averages a single value. Therefore, the average of a single value is that same value.
  2. The author probably started the function object like this:
    type swakExpression;
    outputControl outputTime;
    valueType faceZone;
    zoneName sec9outlet;
    expression ”0.5∗rho*pow(mag(U),2)+p”;
    accumulations
    average
    verbose true ;
    In other words, by using the standard average mechanism that swak4Foam provides.
  3. Problem was that this value wasn't the average that the author was looking for. So, the next step was to do the average manually, just to make sure things still worked as before:
    valueType faceZone;
    expression ”sum((0.5∗rho*pow(mag(U),2)+p)*area())/sum(area())”;
    accumulations
    average
    verbose true ;
    This should be able to perform the same averaging methodology that is used by swak4Foam.
  4. And now, as for the final step, I'm going to ask you Ehsan: Why do you think the author used "area()*rho()" instead of "area()"?
Best regards,
Bruno
Old   May 3, 2013, 05:47
Ehsan
I think its because the flow has been compressible.correct?
this way the average will be more accurate(because of variation of density I think),is it true?
if the mesh is uniform then I think there is no need to sum on area manually,am i correct?!
Old   May 3, 2013, 12:20
Bruno Santos
Yes and yes.
Although I was thinking more along the lines of "mass weighted average" - an even better description on this topic can be found on this thread: http://www.cfd-online.com/Forums/mai...d-average.html - specially on post #20!
As someone once said: better safe than sorry.
It's better to use the area no matter what, to avoid any unpleasant surprises, in case you change the mesh and forget to update this calculation.
Old   May 3, 2013, 13:52
Ehsan
ok.but I think its more satisfying to have min and max as well as true average of a variable field on a plane.
how can I change the function below to have min,max an true average(if I change mesh that I'm going to!)in a single function(so that no more complexity be added to poor controlDict!)
is it possible in your opinion?
sP_h2_velocity
        valueType surface;
        surfaceName horizontal_Plane_2;
        verbose true;
        surface {
            type plane;
            basePoint       (0.0345 0.002 0);
            normalVector    (0 1 0);
            interpolate true;
        expression "mag(U)";
        accumulations (
            min
            max
            average
Old   April 25, 2019, 09:32
Martin
artymk4 is on a distinguished road
I got error because of different multiplication signs in this quoted expression:
expression ”sum((0.5rho*pow(mag(U),2)+p)(area()rho))/(sum(area()rho))”;
when I replaced big asterisks with normal ones (*) the error was gone. So:
expression ”sum((0.5*rho*pow(mag(U),2)+p)*(area()*rho))/(sum(area()*rho))”
wyldckat likes this.
artymk4 is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
