Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
more interpolation points
Old   April 29, 2013, 09:21
Default more interpolation points
achyutan is on a distinguished road
I am using OF-2.0.1. I am trying to validate my solver. the case is supersonic flow over a moving cylinder inside a closed domain. I have got the shock captured well and my density, mach no.. profiles are matching well wrt pattern. Not able to capture the peaks correctly.
When I looked closely into the data files, I found that there may not be enough data points close to the shock. Otherwise, the simulation matches well with actual result.
Now, what i want to know is how to specify (interpolation scheme) in sampleDict file so that i can have more data points close to the shock (shock position is known wrt cylinder).
quick reply would be very helpful
- achyutan
achyutan is offline   Reply With Quote
Old   April 30, 2013, 05:00
I hope i have posted under the appropriate sub-forum this time..
I am waiting for some help !
- achyutan
Old   May 3, 2013, 05:45
unfortunate that no one has yet posted any reply for this !
I am waiting for some help..
- achyutan
Old   May 3, 2013, 08:16
Default sampleDict interpolation
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Hi Achy,
Are you interested in increasing the interpolation points inside a volume, on a plane, or surface? Are you open to increasing the mesh resolution in that area/volume? Please post your current sampleDict using the [ code] [ /code] tags (without the space) so that it is readable.
JR22 is offline   Reply With Quote
Old   May 7, 2013, 06:26
I want to have more interpolation points on a plane capturing the shock. i realize better mesh resolution is one option but i do not want to run the case again. is there any provision in sample dict.
I have attached my sample Dict.
File Type: gz sampleDict.tar.gz (511 Bytes, 9 views)
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 15:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
