-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Time and Temperature in ParaView (http://www.cfd-online.com/Forums/openfoam-post-processing/118109-time-temperature-paraview.html)
massimo May 21, 2013 06:42
Dear all,
i solved a heat transfer problem with a modified chtMultiRegionSimpleFoam solver which is able to deal with heat sources. Now I want to watch the results in ParaView, but there is a problem: When I tick "temperature" as Volume Field and select Color by T, the temperature is visible, but when I change the time from 0 to 2 seconds, the model turns grey again and the option "T" as Volume Field isn't visible anymore. Is there any property I have to change?
It is ParaView version 3.12.0 64-Bit on Ubuntu 12.04.
Thank you in advance.
Best regards,
Max
immortality May 23, 2013 17:28
Hi
go to 1 time and tick temperature.maybe you haven't a T file in 0 folder.
you can also select fields auomaticaly by tick auto accept:its in edit/settings/Auto Accept
