Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Animation of rotating domain in ParaView
Old   May 24, 2013, 07:28
Default Animation of rotating domain in ParaView
Mathias Braun
JackyS is on a distinguished road
I'm fairly new to OpenFOAM and ParaView and have been playing around with the tutorials. One of the examples is the mixerVessel2D from the multiphase tutorials using MRFInterFoam. The calculation works fine and the results are plausible, but for the beauty of it all I would like to animate the rotation of the rotating domain.
I have been searching the internet and I found some examples on youtube but no information on how to do it. I would appreciate any suggestion,
Jack
JackyS is offline   Reply With Quote
Old   May 25, 2013, 13:00
Retired Super Moderator
Bruno Santos
Greetings Jack and welcome to the forum!
There are two possibilities:
  1. Animate only the camera movement: http://www.paraview.org/Wiki/ParaVie...ing_the_Camera
  2. Calculate the movement of the points and transform accordingly... problem is that for this one, you either need:
    • A time field pre-calculated, so that you can use with the normal calculator filter - see section "Working with Point Coordinates": http://www.paraview.org/Wiki/ParaVie...nt_Coordinates
    • ParaView built with Python, so that you can use the "Python Calculator" for calculating this rotation directly in code, or even by using the "Programmable Filter".
Best regards,
Bruno
Old   May 27, 2013, 09:32
Mathias Braun
Hi Bruno,
thank you for the quick answer, you helped me a lot.
I'll make sure and try it out.
Best regards,
Jack
animation, mrf, mrfinterfoam, paraview, ratating domain
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
Monitor a point in a rotating domain taichijulie CFX 0 August 12, 2009 16:25
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Difference b/t rotating wall and rotating domain? Juno Kim CFX 2 February 20, 2007 20:08
