Post-process of a decomposed case
Hi everybody,
I'm trying to post-process a decomposed case. I've tried two ways but no one worked. I tried to postprocess the case using the parafoam -builtin command, but when i set the case type to "decomposed" I receive the following error: Code:
ERROR: In /usr/local/OpenFOAM/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Filtering/vtkExecutive.cxx, line 756 I tried then to reconstruct the case. But reconstructPar gives me this error. Code:
Cannot find file "points" in directory "polyMesh" in times 0 down to constant How can I postprocess this case? And why I'm getting these errors? |
I had also the same error massage: Create time Quote:
I used decomposePar and after that I realized that there is constant - folder in each processor-folder. In the original case (where I get the error massage) were no constant - folder in the processor-folder any more. So I just copied the constant folder from the processor-folder from my new case to the old case and tried reconstructPar again. And it worked :) Maybe this could help you too Regards |
Thank you. i don't need it anymore, but someone maybe does.
Thank you very much. bye |
really appreciate ! it helps me alot
In my case, I had downloaded the simulation from the cluster to my local machine but one of the processor* folders did not contain the files inside its constant folder.
Just complete the processor* folder with the cluster's processor*/constant folder or decompose the case and copy-paste the constant folder. |
