how to delete all folders of same type?
Like Tree2Likes
  • 1 Post By wyldckat
Old   June 13, 2013, 15:43
Default how to delete all folders of same type?
immortality's Avatar
Ehsan
immortality is on a distinguished road
whats the command to delete all folders of a postProcessing result in time folders after seeing and use?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 15, 2013, 17:14
Retired Super Moderator
Bruno Santos
Hi Ehsan,
Sorry, but your question is too ambiguous
Can you describe in more detail?
Best regards,
Bruno
Old   June 15, 2013, 17:33
Ehsan
for example the folders that originated by "Co"(courant number) command.
Old   June 15, 2013, 18:17
Bruno Santos
I've tested running Co with the tutorial case "incompressible/icoFoam/cavityGrade" and it only created the field files "Co" in the already existing time folders. To remove these field files, you can do the following command:
rm */Co
You can see what this command actually does, by running:
echo rm */Co
But if it does create new folders, them the trick should be to first remove the files that were created, by using the command above; and then remove the empty directories with the following command:
for a in *; do rmdir $a; done
It will give several messages indicating that certain files/folders cannot be removed, simply because they are not empty or are not folders. In other words, rmdir will only delete the empty folders.
immortality likes this.
Old   June 19, 2013, 09:05
Ehsan
could you describe me a bit about it?
Old   June 20, 2013, 16:41
Bruno Santos
Hi Ehsan,
It's the same as doing:
for a in *
do
    rmdir $a
done
To know more about each command:
help for
man rmdir
In essence:
  • The asterisk lists all files and folders in the current folder. You can see this if you run:
    echo *
  • rmdir removes empty directories.
  • "for" is ... it is a for cycle!? Not sure how to explain this one, since it's command to several programming languages.
For more information on how to program in the bash shell... Google?
Best regards,
Bruno
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 04:32
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
