Home > Forums > OpenFOAM Post-Processing
Output file transfer from OpenFoam to Ansys Modal
Old   June 28, 2013, 06:27
Default Output file transfer from OpenFoam to Ansys Modal
starter
sihaqqi is on a distinguished road
Hello All
I have carried out LES in openfoam. I have got surface pressure data. Now I want to transfer pressure time data from openFoam to Ansys Modal to carryout Flow Induced Vibrations. Can anyone help?
Regards
sihaqqi is offline   Reply With Quote
Old   June 30, 2013, 07:21
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings sihaqqi,
A bit more information about the kind of data you want to transfer would be useful. Namely:
  1. Do you only need data from said surface?
  2. Or do you also need the mesh?
  3. What kinds of format can you open in Ansys Modal?
Best regards,
Bruno
Old   June 30, 2013, 09:54
starter
Hello Bruno
Thanks for your response. My problem is I want to transfer surface pressure or force vs time data in Ansys Workbench. I do not know if I should import mesh or not as this is the first time I am solving this type of problem. I have attached a formats file which I found in Ansys when I press Imports data tab. However I am still not sure which format I can use.
Regards
Old   June 30, 2013, 17:42
Bruno Santos
Hi sihaqqi,
Well, my guess is that you'll need Fluent to act as the middle-agent in this, because none of those file formats seem to be exportable from OpenFOAM.
If Fluent is out of the question, then I suggest that you ask on the correct ANSYS forum (not sure which sub-forum) how to import CSV data into Ansys Workbench, which will carry the values at each point of said surface.
Best regards,
Bruno
ansys modal
Thread Tools
Trackbacks are On
wmake compiling new solver mksca OpenFOAM Programming & Development 13 August 18, 2014 22:26
swak4Foam-groovyBC build problem zxj160 OpenFOAM 18 July 30, 2013 13:14
build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Installation 14 April 23, 2013 13:59
2.0.x on Mac OSX niklas OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 74 March 28, 2012 16:46
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
