Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating flow rate across a section
Old   June 27, 2013, 04:32
Default Calculating flow rate across a section
Eric Dalmau
edalmau is on a distinguished road
Hi all Foamers,
I've search about how to calculate fields in different parts of my case and I've a doubt about what is better (or maybe the unique way) for calculating the flow across a section of my study case.
The case is a tank with pipe (to simplify) where the fluid flows. Which of these two post-processing at run-time you recommend to my case?
1) fieldValue
2) probes
Maybe there are other options, if any better, please tell me.
Thanks in advance,
Eric
edalmau is offline   Reply With Quote
Old   June 28, 2013, 05:46
Eric Dalmau
I found out that I can use sample to save info across a plane.
I've my SampleDict here but it doesn't work for phi. I read in other posts that it may depend on the interpolation scheme and what kind of "variable" are you trying to store. Phi is defined as SurfaceScalarField.
This leads me to 2 questions:
1) Which kind of interpolation can work with phi assuming I've a plane or cut plane defined?
2) Is there any way to sample an operation between two variables? In my case I need alpha1*phi.
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      sampleDict;
setFormat raw;
surfaceFormat vtk;
formatOptions
    ensight
        format  ascii;
interpolationScheme cell;
fields
    alpha1
    phi
surfaces
  triangleCut
        // Cutingplane using iso surface
        type            cuttingPlane;
        planeType       pointAndNormal;
        pointAndNormalDict
            basePoint       (0.0 1.0 1.54);
            normalVector    (0.0 0.866025 0.5);
        interpolate     true;
If I ran it separately (first alpha1 and then phi) it works for alpha1 but not for phi. I've tried all types of interpolationscheme I found in the dict info but I don't know if there are more not included there.
Any help?
Old   July 2, 2013, 18:36
Assistant Moderator
Bernhard Gschaider
Any help?
I personally use swak4Foam in that kind of situation. It allows me to evaluate whatever combination of fields I want
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 3, 2013, 05:55
Eric Dalmau
Ok thanks I'll take a look on that app. I've look around other posts and for sampling only 1 component of the U vector is there any way to type that? Cause in one post I found "U.component(i)" where i is the component number from 0-2 but it doesn't work for me. The sample app is making only the cutting plane file but not filled with U data only geometrical.
fieldvalue, mrfinterfoam, post-processing, probes, run-time
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
How to calculate phase flow rate? sangramroy FLUENT 0 January 11, 2012 13:02
Calculating mass flow rate cfd novice FLUENT 1 April 3, 2008 18:31
