Home > Forums > OpenFOAM Post-Processing
Using python for post-processing: pythonFlu, swak4foam, ... ?
Old   July 11, 2013, 09:26
Default Using python for post-processing: pythonFlu, swak4foam, ... ?
Francois Beaubert
francois is on a distinguished road
Hi all,
I would like to know if it's possible to use pythonFlu/swak4foam for post-processing data from an already computed case or is it only available at solver run time level ?
When the run is finished, is pythonFlu/swak4foam suited to do things like that:
* get scalar, vector fields into numpy arrays to be able to manipulate them later
* get cell/face center coordinates, faces surfaces, normals to faces ...
* sample data over line/plane/surface (something like OpenFOAM sample utility)
* compute gradient, integral, ....
* etc
I would like to replace Paraview + python scripts by my own Scipy/Matplotlib scripts
Thanks for sharing your experiences.
Regards
Francois
francois is offline   Reply With Quote
Old   July 11, 2013, 11:03
Assistant Moderator
Bernhard Gschaider
Originally Posted by francois View Post
Hi all,
* etc
Regards
Francois
Wie pythonFlu this is possible "out of the box" (once you compiled pythonFlu): as it wraps the usual OF-functionality with a Python-layer you can do anything you can do in OF
In swak4Foam something like a hybrid of funkyDoCalc and the pythonIntegration-functionObject would be possible: calculate some swakVariables then inject the values into the Python-space and drop the user to the Python-shell or execute his script. The problem with this approach is that all the actual OF-specific work (gradients, sampling etc) has to be done in the first (swak)-part.
But thanks for the idea. I might consider implementing such a thing. Feature requests in http://sourceforge.net/apps/mantisbt...?page_number=1 might speed up that decision process. Or maybe someone feels like implementing it (contributions most welcome)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Thread Tools
Trackbacks are On
swak4foam fails in parallel with -otherTime? Phicau OpenFOAM Post-Processing 3 June 26, 2013 13:00
pythonFlu - Python wrapping for OpenFOAM C++ API alexey2petrov OpenFOAM Announcements from Other Sources 13 December 21, 2012 12:43
How to get Python Shell into ParaView 3.8.1? blaise OpenFOAM Installation 3 July 24, 2012 04:58
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 09:36
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
