-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   how to sum force of the multi-element wing (http://www.cfd-online.com/Forums/openfoam-post-processing/121052-how-sum-force-multi-element-wing.html)
hewei July 20, 2013 05:20
Hi everyone,
now I try to calculate the multi-element wing's force coefficient, there are one main wing and a flap , I use the function
functions
{ forces
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 1;
patches
wing_main
wing_flap
rhoName rhoInf;
log true;
rhoInf 1;
CofR ( 0 0 0 );
liftDir (0 1 0 );
dragDir ( 1 0 0 );
pitchAxis ( 0 0 1 );
magUInf 10;
lRef 1.0;
Aref 1.0;
but the openfoam just output the last order patches value (here is flap), I can not get the total force acting on the wing. so anyone knows how to sum the force? thank you!
DLuo February 3, 2014 18:38
The ForceCoeffs library is a little weird when it comes to integrating on multiple BCs. I had success once when instead of using line breaks to delineate BCs, keep them on the same line and separate them by space. i.e.
patches ( wing_main wing_flap );
A better approach is to be clever about your naming convention. In this case it's fairly simple; both of your BCs start with "wing_", therefore you can wildcard out the latter part of the names and have it integrate on anything that starts with "wing_"
patches ( "wing_.*" );
The quotes are required for wildcards to work, and the .* is what initiates the wildcard.
This wildcard approach can also be used in setting up multiple BCs with similar names and similar Boundary conditions (e.g. fixed no-slip walls)
You can find an example for yourself in the tutorials. incompressible/simpleFoam/motorBike
