Home > Forums > OpenFOAM Post-Processing
Errormassages while reconstructing
Old   July 25, 2013, 10:18
Default Errormassages while reconstructing
Hendrik
hotti24 is on a distinguished road
Hey Guys,
i got an error message every time i try to reconstruct the "twoSpheresGlowinskiMPI" tutorial from CFDEM (this is in the CFD - DEM coupled Simulation). I have found a alternating script in this forum, which makes for each time step
reconstructParMesh -mergeTol 1e-06 -time $line > logTmp;
and then
reconstructPar -time $line > logTmp;
. The Error appears in the last command.
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::objectRegistry::checkOut(Foam::regIOobject&) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::regIOobject::~regIOobject() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::IOList<int>::~IOList() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6  Foam::processorMeshes::read() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libreconstruct.so"
#7  Foam::processorMeshes::readUpdate() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libreconstruct.so"
 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/reconstructPar"
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
./alternating.sh: Zeile 4: 10866 Speicherzugriffsfehler  (Speicherabzug geschrieben) reconstructPar -time $line > logTmp
Does anyone have a idea what i can to to fix this problem? The coupled simulation was started by using the following commands in the CFD folder:
blockMesh
checkMesh
decomposePar
mpirun.openmpi  -np 4 cfdemSolverIB -parallel #> log
but the Allrun.sh script one folder higher works as well. With this scipt a got a Oktave curve, but I want to have a visualisation in paraFoam.
May anyone can help me, please.
Greetings,
Hendrik
hotti24 is offline   Reply With Quote
Thread Tools
Trackbacks are On
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 11:25
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 22:36
Check yPlus without reconstructing in parallel runs maysmech OpenFOAM 3 September 14, 2010 16:14
Paraview decomposed case without reconstructing? HelloWorld OpenFOAM 3 May 8, 2010 09:47
Problem of reconstructing pointVectorFields with parallel mesh motion (1.5.x) LESlie OpenFOAM 0 November 6, 2009 07:07
