July 29, 2013, 09:40 |
preventing of writing of excess folders
Ehsan
Rep Power: 26 |
in time folders some as look excess folders like ddt0(rho),k_0,ddt0(rho,U),...
most of them with a 0 suffix are written in time folders. what do they for solver and how can prevent writing them in time folders due to no need to them in post processing.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
July 29, 2013, 09:45 |
Bernhard
Rep Power: 21 |
As far as I know, they are needed for restarting, depending on your time-integration scheme, as it stores the previous time step.
July 29, 2013, 10:21 |
Ehsan
Rep Power: 26 |
thanks,then its because of crankNicolson I have chosen as time scheme.
July 29, 2013, 10:56 |
Lieven
Rep Power: 22 |
Hi Ehsan,
That is exactly the reason. If you would take Euler you won't get those files. If you think about it, it makes perfectly sense that 2 previous time steps to restart a second order time integration scheme. If you would write the output after every iteration, you will see that the "U_0" is exactly the same as the "U" file of the previous time step. Cheers, Lieven |
How to Mix AIR and WATER | Elvis1991 | FLUENT | 12 | December 1, 2016 12:28 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
solid to fluid heattransfer with chtMultiRegionFoam | nakor | OpenFOAM | 11 | March 21, 2011 08:28 |
journal file command for writing mass flow rate | James | FLUENT | 0 | July 26, 2006 10:51 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 08:48 |
