Home > Forums > OpenFOAM Post-Processing
Extracting cell centre values WITHOUT interpolation
Old   August 17, 2013, 23:35
Default Extracting cell centre values WITHOUT interpolation
Aaron
dalaron is on a distinguished road
I would like to extract cell centre values without using any interpolation schemes. My sampleDict file is as follows:
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \\/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
location    "system";
object      sampleDict;
interpolationScheme cell;
setFormat       raw;
sets
centrePatch
type    uniform;
axis    x;
start   0 0 0 ); // start of sample region
end     8.11734270322 0 0 ); // end point of sample region
nPoints 50;
fields          Ux p T );
The problem I am having is what to do with nPoints. I would ideally like to have this automatically match the number of cells I have without me having to specify it. For example if my grid hasd 50 cells in the horizontal direction I could go
PHP Code:
 nPoints nDomain
(or some other keyword), instead of having to specify manually
PHP Code:
 nPoints 50
Is this something that can be done?
Using nPoints 50; gives me the following temperature plot. As you can see, towards the end of the domain the sample points from my solution are more noticeably clustered in pairs.
dalaron is offline   Reply With Quote
Old   August 18, 2013, 00:39
Aaron
I believe I have solved my problem. Here is the sampleDict with modifications:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      sampleDict;
setFormat       raw;
sets
    centrePatch
        type    midPoint;
        axis    x;
        start   ( 0 0 0 );
        end     ( 8.11734270322 0 0 );
fields
    Ux
    p
    T
I used
 type    midPoint;
and removed the nPoints part of the sampleDict file.
I still have the issue of 'clustered' pairs of temperature points and am not sure what is causing that, though they now much more closely match the theoretical predication. Is this something I should even be looking into? Plots for Pressure, Density, and Mach number do not have this issue (or if they do it much, much less obvious).
Thread Tools
Trackbacks are On
Setting cell variable values in a fluid zone using UDF eromon84 Fluent UDF and Scheme Programming 5 October 15, 2013 05:16
Calculate Cell Centre to Cell Face Distances iamed18 OpenFOAM Programming & Development 15 October 10, 2012 06:09
Cell face values computation un unstructured grids Sergio Rossi Main CFD Forum 2 May 28, 2006 10:04
Interpolation for ghost cell help zonexo Main CFD Forum 0 March 11, 2006 21:03
interpolation from cell center to vertices Zhang Main CFD Forum 3 August 22, 2003 07:31
