-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   How to run python script to plot sth WITHOUT reconstructPar (http://www.cfd-online.com/Forums/openfoam-post-processing/122892-how-run-python-script-plot-sth-without-reconstructpar.html)
ripperjack August 30, 2013 13:41
Hi all,
I have a large case (mesh > 20M) calculated using 200+ cores. So I need to use python script to extract some contours, profiles, etc. I have figured out how to do it using .py script. But I have a problem that every time I run the .py script, I need to run reconstructPar first and it is time-consuming. Is there a way to do it WITHOUT reconstruct. e.g., use sth like -builtin option for paraFoam.
Thanks in advanced!
gschaider September 2, 2013 19:35
Originally Posted by ripperjack (Post 448951)
Hi all,
Thanks in advanced!
With "contours, profiles" you mean sample lines and surfaces? AFAIK sample works in parallel. So just run it on your 200+ cores
