Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Not able to store the velocity data In edited pimpleFoam
Old   September 16, 2013, 08:04
Question Not able to store the velocity data In edited pimpleFoam
Himanshu Sharma
himanshu28 is on a distinguished road
I have edited pimpleFoam to solve the Turbulent flow, heat transfer case and i have build my solver successfully and performed the validation also.
I am able to plot the velocity contours and able to see the velocity magnitude in the paraview.
But i am not able to see the Ux,Uy,Uz values in the log file generated after the solution even after using the FoamLog ,to plot the residuals.
So please somebody help me to come out of this problem.I have tested the case of TJunction of pimple Foam without heat equation and its printing the Ux ,Uy,Uz properly and even i use this T junction only to test the developed solver but is now printing the velocity components..
Regards
Himanshu
himanshu28 is offline   Reply With Quote
Old   September 16, 2013, 09:59
Talking Solution to the stated problem
Himanshu Sharma
Originally Posted by himanshu28 View Post
Regards
Himanshu
Hi Foamers,
I got the solution for the problem this was happening because in my fvSolution file i wrote the following lines
momentumPredictor  no
and if you closely observe the UEqn for the pimpleFoam then U will find that the velocity correction based on the computed pressure value is assigned with the if condition.
hence I changed the
momentumPredictor  yes
and it started printing Ux, Uy,Uz with the the log file and now i can monitor the residuals easily.
One more thing if you don't add this line in ur fvSolution then it will be by default taken as yes.
Sorry for spamming but hope some body in future can use this advice if he get stuck.
Regards
Himanshu
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 04:46
unable to get parabolic velocity profile with pimplefoam houkensjtu OpenFOAM 4 October 8, 2012 04:41
[Help Please], Trouble Using UDF to Import Velocity Data -- But All Zeros :( rockymountai FLUENT 1 November 11, 2009 16:30
transient velocity profile with experimental data Janneke FLUENT 3 August 19, 2008 10:11
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
