-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Different surface flow values - Incompressible case (http://www.cfd-online.com/Forums/openfoam-post-processing/125072-different-surface-flow-values-incompressible-case.html)
kornickel October 18, 2013 06:16
3 Attachment(s)
Hi everyone,
I have an incompressible (simpleFoam) MRF case with an axial fan in a tube (see screenshots). I also got realistic solutions but if I ask paraview to give me the surface flow I get different flows at the outlet and at the middle of the outlet tube. The value at the middle of the outlet tube (0.05437 m/s) is also more realistic than the outlet value (0.0532 m/s). Why that? Shouldn't it be the same values since it's an incompressible case?
I made a slice at both positions and got the flow value via the "Surface Flow" filter.
I also enclosed two screenshots of the glyphs mid-tube (glyph_mid.png) and at the outlet (glyph_out.png).
Does anyone know what's going on here?
Best regards,
Frank Ubber
kornickel October 20, 2013 06:54
Does anybody have an idea? How to correctly read out the surface flow or why I have different flow values?
vinz October 21, 2013 04:47
Dear Frank,
There could be few reasons:
- either your case is not fully converged
- either your mesh is not good enough and you get some mass loss
- either your farfield (cylinder tube) is not a wall boundary condition and you get some inflow/outflow there as well.
