[swak4Foam] I have warning in use swak4Foam
Old   October 25, 2013, 02:59
Assistant Moderator
Bernhard Gschaider
Originally Posted by seju View Post
my libraries are:
PHP Code:
sajad@sajad-K55VD:~$ ls $FOAM_USER_LIBBIN
libgroovyBC
.so
libgroovyStandardBCs
.so
libsimpleLagrangianFunctionObjects
.so
libsimpleSearchableSurfaces
.so
libswak4FoamParsers
.so
libswakChemistryModelFunctionPlugin
.so
libswakFvcSchemesFunctionPlugin
.so
libswakLagrangianCloudSourcesFunctionPlugin
.so
libswakLocalCalculationsFunctionPlugin
.so
libswakMeshQualityFunctionPlugin
.so
libswakRadiationModelFunctionPlugin
.so
libswakRandomFunctionPlugin
.so
libswakSourceFields
.so
libswakSurfacesAndSetsFunctionPlugin
.so
libswakThermoTurbFunctionPlugin
.so
libswakTopoSources
.so
libswakTransportTurbFunctionPlugin
.so
libswakVelocityFunctionPlugin
.so
how can I add libraries in swak and complite swak??
I have to add these libraries to swak because I so need these libraries.
OK. simpleFunctionObjects and libraries based on this are missing. Probably there was a problem during compilation. Probably about a method that was recently added to the functionObject-class.
Have a look at the error message: there is already a fix on the MessageBoard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 26, 2013, 03:54
sajad
seju is on a distinguished road
now,I must recompiling this swak or cleaning this swak and compile other swak?
whats a complete swak address in net which I download and compile it.???
my openFoam is 2.2.1 and my swak is 0.2.4
seju is offline   Reply With Quote
Old   October 26, 2013, 06:04
Retired Super Moderator
Bruno Santos
Greetings to all!
@seju:
If my memory doesn't fail me, it's written on this post: http://www.cfd-online.com/Forums/ope...tml#post434217 - post #8
If this doesn't work, please provide more details on the steps you are taking, as well as how exactly you installed OpenFOAM on your machine.
In addition, if you also have OpenFOAM 1.6-ext, please detail how you switch between the two versions.
Best regards,
Bruno
Old   October 26, 2013, 07:52
sajad
Originally Posted by wyldckat View Post
Greetings to all!
@seju:
Best regards,
Bruno
I downloaded swak this link
PHP Code:
https://github.com/wyldckat/swak4foam/tree/OF22X
but this swak dont have some libraries.I install openFoam 2.2.1 on ubuntu 13.04.
I have ubuntu and windows 7 abreast.I dont install openfoam in virtualbox.I install ubuntu absolute.
I fialed in compile openFoam 1.6 ext and I just have openFoam 2.2.1.
I installed openFoam 2.2.1 From this link
PHP Code:
http://www.openfoam.org/archive/2.2.1/download/
Old   October 26, 2013, 08:51
Bruno Santos
Hi seju,
Many thanks the information! I've tested the following steps on a VM with Ubuntu 13.04 (64bit) and with the same OpenFOAM 2.2.1 installation and they should work as intended:
  1. I downloaded and unpacked like this:
    cd ~
    mkdir OpenFOAM
    cd OpenFOAM
    wget https://github.com/wyldckat/swak4foam/archive/OF22X.zip
    unzip OF22X.zip
    cd swak4foam-OF22X/
  2. Then ran this command, just in case some other version is contaminating the shell environment:
    wmUNSET
  3. Then prepared the shell environment:
    source /opt/openfoam221/etc/bashrc
    export WM_NCOMPPROCS=4
    Change the 4 to the number of cores your machine has got. If you don't know, change it to 1.
  4. Build swak4Foam:
    ./Allwmake > make.log 2>&1
  5. Run the command a second time:
  6. Now open the file "make.log" and check its contents. For example, run:
    cat make.log
    It should show you something like this:
    No 'swakConfiguration'. Python etc won't work
    Checking swak4Foam-version and generating file
    Swak version is 0.2.4
    Bison is version 2.5
    Flex is version 2.5.35 (Minor version: 35)
    OpenFOAM-version: Major 2 Minor 2 Patch 1 (-1 == x)
    No change to swak4FoamParsers/foamVersion4swak.H
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libsimpleFunctionObjects.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libsimpleSearchableSurfaces.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakTopoSources.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakSourceFields.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libgroovyStandardBCs.so' is up to date.
    SWAK_PYTHON_INCLUDE not defined .... no Python-Integration
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakRandomFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakFvcSchemesFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakVelocityFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakChemistryModelFunctionPlugin.so' is up to date.
    '/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so' is up to date.
    make[1]: `/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/bin/funkyDoCalc' is up to date.
    make[1]: `/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/bin/funkySetBoundaryField' is up to date.
    make[1]: `/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/bin/calcNonUniformOffsetsForMapped' is up to date.
    make[1]: `/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/bin/funkySetFields' is up to date.
    make[1]: `/home/user/OpenFOAM/user-2.2.1/platforms/linux64GccDPOpt/bin/replayTransientBC' is up to date.
    If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/user/OpenFOAM/swak4foam-OF22X/Libraries (most people will be fine without setting that variable)
Best regards,
Bruno
Old   October 27, 2013, 02:45
sajad
dear Bruno and Mr.Gschaider my problem solved.thank you so much.
but I have another problem in:
HTML Code:
http://www.cfd-online.com/Forums/openfoam-meshing/125508-problem-axisymmetric-mesh.html#post459204
Last edited by wyldckat; January 2, 2014 at 08:40. Reason: removed very long and unnecessary quote ;)
Old   January 2, 2014, 06:50
Default Problems building swak4Foam
  #27
Seif Kefi
Seif Kefi is on a distinguished road
Hi everyone,
First of all, happy new year!
I am a new Foamer. And, this is my first post.
I am using ubuntu 13.10 and have installed openFoam 2.2.2. What I want to do is to modify the wind velocity profile in the turbineSiting tutorial. So, I decided to download swak4Foam in order to use groovyBC. But, when I use it, it seems that it was not built in the right way. I even used these two patches:
1. http://www.cfd-online.com/Forums/ope...tml#post415028)
2. http://www.cfd-online.com/Forums/ope...tml#post434217
Here is the error messages I get:
seif@seif-ThinkStation-E31:~/OpenFOAM/seif-2.2.2/run/tutorials/incompressible/simpleFoam/turbineSiting$ foamCalc mag U
Selecting calcType mag
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.2-9240f8b967db
Exec   : foamCalc mag U
Date   : Jan 02 2014
Time   : 19:25:49
Host   : "seif-ThinkStation-E31"
PID    : 6486
Case   : /home/seif/OpenFOAM/seif-2.2.2/run/tutorials/incompressible/simpleFoam/turbineSiting
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM Warning :
    From function dlOpen(const fileName&, const bool)
    in file POSIX.C at line 1179
    dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
    could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
    dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    could not load "libswakFunctionObjects.so"
--> FOAM Warning :
    dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    could not load "libgroovyBC.so"
Create mesh for time = 0
Time = 0
    No U
End
Cheers,
Seif
Seif Kefi is offline   Reply With Quote
Old   January 2, 2014, 08:43
Bruno Santos
Greetings Seif and welcome to the forum!
Try these steps:
  1. Install the necessary development system packages, since you are using Ubuntu:
    sudo apt-get install build-essential flex bison zlib1g-dev
  2. Then try following the instructions from the post above, namely post #25
Best regards,
Bruno
Old   January 2, 2014, 20:54
Seif Kefi
Hi Bruno,
Thank you for your relpy. But, following these steps, here is the error messages I get:
 ../FieldValueExpressionParser.yy:5499:13: note: in expansion of macro ‘sameSize’
lnInclude/swakChecks.H:63:92: error: ‘yylloc’ was not declared in this scope
 #define sameSize(a,b) {Foam::string err=Foam::swakAssertSameSize(a,b); if(err!="") { error(yylloc,err); YYERROR; }}
../FieldValueExpressionParser.yy:5507:13: note: in expansion of macro ‘sameSize’
../FieldValueExpressionParser.yy:5514:13: note: in expansion of macro ‘sameSize’
make: *** [Make/linux64GccDPOpt/FieldValueExpressionParser.o] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Best regards,
Seif
Old   January 4, 2014, 19:10
Bruno Santos
Hi Seif,
What does the file "make.log" have in its first 10 lines?
Best regards,
Bruno
Old   January 7, 2014, 00:59
Seif Kefi
Hi Bruno,
First of all, sorry for my late reply. Here are the first 10 lines of the log file:
Bison is version 3.0
OpenFOAM-version: Major 2 Minor 2 Patch 2 (-1 == x)
SOURCE=FieldValueExpressionParser.yy ; rm -f Make/linux64GccDPOpt/FieldValueExpressionParser.C Make/linux64GccDPOpt/FieldValueExpressionParser.tab.hh; mkdir $$; cd $$; bison -ra -v -d ..
Best regards,
Seif
Old   January 7, 2014, 18:24
Assistant Moderator
Bernhard Gschaider
Originally Posted by Seif Kefi View Post
Hi Bruno,
Best regards,
Seif
"Danger, Will Robinson, Danger". Bison 3.0 seems to be incompatible with 2.x (which swak currently supports). Use the latest 2.x-version instead.
May I ask: which Distro installs Bison 3 by default? Or did you install it yourself from the sources?
Old   January 10, 2014, 14:14
Bruno Santos
Greetings to all!
@Bernhard:
Seif mentioned Ubuntu 13.10, but I checked packages.ubuntu.com and Ubuntu 13.10 (Saucy) uses Bison 2.7.1 by default; only in Ubuntu 14.04 will it apparently use Bison 3.0.2 (which should be released in 3 months!?).
My guess is that Seif built Bison 3.0 from source code?
Best regards,
Bruno
Old   January 22, 2014, 19:28
Assistant Moderator
Bernhard Gschaider
Greetings to all!
@Bernhard:
Best regards,
Bruno
Bison3 seems to break a number of packages http://trac.macports.org/ticket/39910
BTW: just checked. The development version checks for bison3 and refuses to go further (must have put that in around the time of the above MacPorts-ticket)
From my short look it seemed that the changes necessary to the swak-grammar-files would make them incompatible with bison 2.x. And as long as there is not a significant portion (5-10%) of the Linux-installations out there with bison 3.x I don't consider converting (because that would force people to hand install a bison 3.x on top of the one they already have)
Old   January 27, 2014, 01:06
Seif Kefi
Hi Bernhard,
What do you recommend me to do?
Best,
Seif
Old   January 27, 2014, 05:09
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Obviously install the latest 2.x-version of bison
Either using the package manager of your OS (that is preferred). If that is not possible download the sources and compile it from there (that is described in the README that comes with those sources). Only two things: use the --prefix-option of configure to "install" it to a private directory (don't overwrite the system-bison) and add the directory to the PATH before compiling.
As you're using a cutting-edge distro (which distro ARE you using, by the way?) you should be comfortable with these instructions. If you're not I'd recommend using a more mainstream-distribution
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
