Average velocity in volume
Hi FOAMers,
I calculated the velocity for flow inside a cube, now I want to calculate the average velocity of fluid (single phase) in this cube (volume), How can I do that in ParaFOAM? It seems simple but I could not calculate that Thank you for your comments. Kind Regards |
You might want to try the foamCalcEx utility: http://openfoamwiki.net/index.php/Contrib_foamCalcEx
This allows the calculation you want from the command line directly. |
Thanks
That is the exact thing which I need. :D
and what if I want to write the output in a file?
So I am new to openfoam and I found the funkyDoCalc utility helpful, the problem is that funkyDoCalc does not record the result... Any suggestions??
