Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Plotting residual in OpenFoam
Like Tree1Likes
  • 1 Post By wyldckat
Old   February 27, 2013, 14:20
Question Plotting residual in OpenFoam
AndreiCFD
andrei.cimpoeru is on a distinguished road
Has anyone any idea how to plot the residuals in OpenFoam from a >.log file ?
Many thanks
Andrei
andrei.cimpoeru is offline   Reply With Quote
Old   February 27, 2013, 15:58
cutter is on a distinguished road
you could try pyFoamPlotWatcher.py from the PyFoam utilities.
cutter
cutter is offline   Reply With Quote
Old   February 27, 2013, 16:18
Sasan Ghomi
sasanghomi is on a distinguished road
Hi ,
Copy the code in a txt file and set it in the case directory,
set logscale y
set title "Residuals"
set ylabel 'Residual'
set xlabel 'Iteration'
plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,\
"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,\
"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\
"< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,\
"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,\
"< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines
pause 1
reread
gnuplot Residuals -
Now type (in the terminal):
gnuplot residual
It needs gnuplot ...
Sasan.
sasanghomi is offline   Reply With Quote
Old   February 28, 2013, 07:08
Bernhard
Bernhard is on a distinguished road
The foamLog utility is designed for it. It will extract the residuals and put them in different files.
Bernhard is offline   Reply With Quote
Old   February 28, 2013, 07:13
AndreiCFD
I used the foamLog and I have the files I used excel package which comes with ubuntu 11.10 but i want to something which is automatically ........
Old   February 28, 2013, 07:15
Bernhard
Then you should dig into the first answer you got.
Old   February 28, 2013, 08:24
Retired Super Moderator
Bruno Santos
Quick answer: http://www.cfd-online.com/Forums/ope...residuals.html
cutter likes this.
Old   March 1, 2013, 08:00
Martin
wernsen is on a distinguished road
pyFoamPlot... is the best to do this job ad its simple too!
wernsen is offline   Reply With Quote
Old   October 24, 2013, 06:31
chen long
Jackie Chen is on a distinguished road
no command found. is this a valid command?thanks
Jackie Chen is offline   Reply With Quote
Old   October 24, 2013, 06:45
Eysteinn Helgason
eysteinn is on a distinguished road
You need to install pyFoam:
http://openfoamwiki.net/index.php/Contrib_PyFoam
eysteinn is offline   Reply With Quote
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
