-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Missing output of sampledSet (http://www.cfd-online.com/Forums/openfoam-post-processing/125418-missing-output-sampledset.html)
letzel October 25, 2013 03:31
With the controlDict of tutorials/incompressible/icoFoam/cavity modified as follows,
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.2.2                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      controlDict;
application    icoFoam;
startFrom      startTime;
startTime      0;
stopAt          endTime;
endTime        0.5;
deltaT          0.005;
writeControl    timeStep;
writeInterval  20;
purgeWrite      0;
writeFormat    ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision  6;
runTimeModifiable true;
functions
  profile01
    type sets;
    enabled true;
    outputMode timeStep;
    outputInterval 1;
    verbose false;
    set (
      type uniform;
      axis y;
      start ( 0.5 0 0.05 );
      end  ( 0.5 1 0.05 );
      nPoints ( 100 );
    setFormat xmgr;
    fields ( U );
the expected run-time output of the sampledSet is not written to disc, but the screen log shows no error:
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.005
Courant Number mean: 0 max: 0
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 2.96338e-06, No Iterations 8
DILUPBiCG:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG:  Solving for p, Initial residual = 1, Final residual = 7.55402e-07, No Iterations 35
time step continuity errors : sum local = 5.03809e-09, global = 4.40722e-19, cumulative = 4.40722e-19
DICPCG:  Solving for p, Initial residual = 0.523591, Final residual = 9.72352e-07, No Iterations 34
time step continuity errors : sum local = 1.07766e-08, global = 2.93897e-19, cumulative = 7.34619e-19
ExecutionTime = 0.01 s  ClockTime = 0 s
Time = 0.01
Courant Number mean: 0.0976805 max: 0.585722
DILUPBiCG:  Solving for Ux, Initial residual = 0.148584, Final residual = 7.15711e-06, No Iterations 6
DILUPBiCG:  Solving for Uy, Initial residual = 0.256618, Final residual = 8.94127e-06, No Iterations 6
DICPCG:  Solving for p, Initial residual = 0.379232, Final residual = 3.38648e-07, No Iterations 34
time step continuity errors : sum local = 3.15698e-09, global = 1.94222e-19, cumulative = 9.28841e-19
DICPCG:  Solving for p, Initial residual = 0.286937, Final residual = 5.99637e-07, No Iterations 33
time step continuity errors : sum local = 6.08774e-09, global = 5.80474e-19, cumulative = 1.50932e-18
Time = 0.015
How can I achieve the expected output?
letzel October 25, 2013 10:49
While I could not solve the problem initially reported for the test case above, I did solve it for a production case. Formatting was wrong.
The following is a working example just for reference. Note that not all libs may be required for this excerpt.
libs (
        "libOpenFOAM.so"
        "libsampling.so"
        "libsimpleSwakFunctionObjects.so"
        "libswakFunctionObjects.so"
functions
  profiles
    type sets;
    enabled true;
    verbose true;
    interpolationScheme cellPoint;
    outputControlMode outputTime;
    setFormat xmgr;
    fields ( wuav wsusav wvav wsvsav Iav );
    sets
      profile01
        type uniform;
        axis y;
        start ( 20  0 56 );
        end  ( 20 50 56 );
        nPoints 100;
      profile02
        type uniform;
        axis y;
        start ( 40  0 56 );
        end  ( 40 50 56 );
        nPoints 100;
