Gnuplot from sampledict output
Old   November 8, 2013, 04:46
Default Gnuplot from sampledict output
Sujatha is on a distinguished road
I am trying to get plot of pressure along a line from sampledict output directly in gnuplot. But when I type the "sample" keyword after running the problem, I get a set folder in the postprocessing folder. These contains files with ".gplt" extension. I tried to call these to the gnuplot using "plot" command in the terminal as per usersguide, I got a message saying the file cannot be read and no graph is created.
I have seen similar issues in other threads but no answers that helps me.
Any hint will be a privilege and is greatly appreciated.
Thanks in advance.
regards,
Sujatha
Sujatha is offline   Reply With Quote
Old   November 9, 2013, 03:43
Lieven
Lieven will become famous soon enough
Hi Sujatha,
You can use the files directly as input for gnuplot:
$ gnuplot the_file_name.gplt
which will directly create an image file
Cheers,
L
Lieven is offline   Reply With Quote
Old   November 9, 2013, 23:43
Thank You sir, Lieven for your kind response.
I tried the command and I am getting the message as
gnuplot the_run/pressgnu2/sampobs/postProcessing/sets/0.1_lineX1_p.gplt
Cannot open load file 'the_run/pressgnu2/sampobs/postProcessin/sets/0.1_lineX1_p.gplt'
line 0: util.c: No such file or directory
I have tried the command for different cases and couldn't get the plot.
I will be grateful if you could suggest me some possible solution.
Thanks again.
Regards
Sujatha
Old   November 10, 2013, 17:23
Lieven
Are you sure you entered the fileName correctly? Cause in your error message you say "postProcessin" instead of "postProcessing"
Cheers,
L
Old   November 11, 2013, 10:01
Thank You Sir, Lieven,for the response. It's 'postProcessing', I have left the 'g' while I was copy -pasting it.
I have tried for more than one simulation, but couldn't get the plot. Will that be any other sort of error? While entering the file name i guess we need to write the entire path , excuse me if I am wrong.
Thanks again.
Regards,
Sujatha
Old   November 11, 2013, 10:10
Lieven
Hi Sujatha,
What does
cd the_run/pressgnu2/sampobs/postProcessing/sets/
gnuplot 01_lineX1_p.gplt
give you? Do you get the same error? Which version of gnuplot are you using (gnuplot -h)
Cheers,
L
Old   November 11, 2013, 13:19
Sir,Lieven,
I'm grateful for your kind response.
Now I get an error message as "the_run undefined" and when I removed it from the code I got the error message as "invalid command".
I'm using Gnuplot 4.4, I could plot functions, etc using this, except for plotting with a data file directly obtained from sampleDict.
Thanking You,
Regards
Sujatha
Old   November 11, 2013, 14:48
Lieven
Hi Sujatha,
Let me rephrase it to English instead of bash-coding: you should navigate in a terminal to the folder where the 01_...gplt-file is stored. Once in that folder you should open the gplt file with gnuplot.
The 'the_run/...' is simply the path that I copied from your previous post. It's impossible for me to verify if this really is the correct path. But it's probably not since it returns an error.
Cheers,
L
Old   November 11, 2013, 23:33
Sir, Lieven, Thanks a million. I tried with the path name and then called the file with the command gnuplot as: run/pressgnu2/sampobs/postProcessing/sets/0.1$ gnuplot lineX1_p.gplt .
I got the graph. Thanks again sir.
Regards,
Sujatha
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
sampleDict output needs to be fixed! musahossein OpenFOAM Post-Processing 17 September 13, 2013 21:51
RNG diverged during the analysis the flow over a multi element airfoil, why? s.m OpenFOAM Running, Solving & CFD 0 August 5, 2013 08:39
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
