Home > Forums > OpenFOAM Post-Processing
wallShearStress not calculated
Old   November 20, 2013, 13:59
Default wallShearStress not calculated
ArathoN
ArathoN is on a distinguished road
I'm studying the Backward facing step with inclined step, and i decided to mesh the geometry in Gambit. Now i'm having a problem in using the utility wallShearStress, it gives only null values of the shear in the x,y,z directions? Why? what can i do? I specified correctly the boundaries from gambit and also from the bondaries file too.
ArathoN is offline   Reply With Quote
Old   November 20, 2013, 14:08
ArathoN
I must specify that the sampling of the wallshearstress can't be done, otherwise the variable is calculated.
Here my sample file:
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      sampleDict;
setFormat gnuplot;
surfaceFormat raw;
interpolationScheme cellPoint;
fields
    "wallShearStress"
sets
lineX1
        type        face;
        axis        x;
        start       (0 -0.1 0);
        end         (2.5 -0.1 0);
        nPoints     400;
surfaces
 walls_interpolated
        type            patch;
        patches         ( "lowerWall" );
        interpolate     true;
it gives me this error:
surfaces surfaces: Reading surface description:
    walls_interpolated
Time = 0
--> FOAM FATAL IO ERROR:
size 30 is not equal to the given value of 40
file: /home/arathon/Tesi/Cases/K-E/BackwardFacingStep-15/0/wallShearStress.boundaryField.inlet from line 26 to line 27.
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
Thread Tools
Trackbacks are On
Problems with YPlusRAS and wallShearStress Peter85 OpenFOAM Post-Processing 21 May 4, 2016 05:15
wallShearStress, wallGradU are inconsistent dancfd OpenFOAM Post-Processing 4 May 4, 2016 04:52
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 19:30
dsmcFoam setup hherbol OpenFOAM Pre-Processing 0 July 14, 2013 17:16
wallShearStress VS wallGradU bigrock OpenFOAM Post-Processing 0 July 2, 2013 05:54
