Calculated Drag Differences Paraview vs OpenFoam Output
Hi guys,
just want to ask for comments: Drag Coefficient Output @ OpenFoam ControlDict -> 2.83 (like literature) Paraview PostProcessing Calculation -> 2.49.... These are my paraviewsteps in short: 1)Extracted Surface 2)Generate Surface Normals 3)Calculated: cp = normals*p; ->Pressure Drag cf=normals*mu*wallGradU_y -> Friction Drag 4) Build Integral Drag=(cp_X+cf_X)*3.14156 (for Aref=1) equals in 2.49 Did I miss something? |
Ok, this is just a guess from my side:
Could be the differences caused by derivation error while building dUdY of parafoam? |
I am still not sure about this topic, has got anyone any idea? Is there something wrong in my workflow?
My reference Area Aref is set to 1 in controldict and my density rho to 1.2. Is paraFoam normalizing the data in strange way? |
Did you find the solution? I also have some difference about drag calculations like you. I use the same workflow.... Best regards, Ye |
You might try to evaluate the sensitivity of forces to angle in surface normals.
Regards, Hannes |
friction drag
Hi all,
isn't the difference due to the friction drag (which you don't take into account when using only the pressure in paraview)? Regards, Wouter. |
