-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   simpleFoam vs buoyantSimpleFoam (http://www.cfd-online.com/Forums/openfoam-post-processing/129347-simplefoam-vs-buoyantsimplefoam.html)
openFUser February 3, 2014 12:13
Dear Foamers,
I am quite new to use OF to solve external aerodynamics. I am writing here to ask for your kind help.
I try to simulate a cube placed on the ground on a face in order to understand how OF manage the force calculation with simpleFoam and with buoyantSimpleFoam.
The point is that I should get the same value of forces on the cube, but something is wrong...
I tried to compare the data in the postProcessing/forces folder with the value obtained by the integral of pressure on the cube's surfaces in paraFoam but i cant get the point.
Maybe I make some mistakes: to integrate pressure on faces I generate surface normals on the cube and the integrate the calculated variable p*normals.
The topics are these:
1. there is any differences on forceCalculation between simple and buoyant?
2. why the intergals of (p*normals) do not match with the force calculation of postProcessing folder?
I'd like to thank anyone could help me...
Here below there some values:
/*___with simpleFoam___*/
P
pressure 0;
dimensions [0 2 -2 0 0 0 0];
--> after 50k iter
forces(pressure, viscous, porous)
(-1.677823966 -0.04192667675 0.8973219913) only pressure
while with the integrateVariable on P
1.47393 -0.0309424 -0.895828
/*___withbuoyantSimpleFoam____*/
P
pressure 101325;
dimensions [1 -1 -2 0 0 0 0];
P_RGH
pressure 100000;
--> after 50k iter
(-3.544135454 -0.2622319888 -24650.00027) only pressure
while with the integrateVariable on P_rgh
193.717 421.979 26073.8
193.71 421.967 26072.3
