Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Friction velocity in Channel flow
Old   May 13, 2010, 18:45
Default Friction velocity in Channel flow
Kim Yusik
impecca is on a distinguished road
Dear Foamers.
I use a pisoFoam based solver and have turbulent inlet boundary(using LES), I hope the turbulence doesn't decay or develop through channel.(like channelFoam)
To normalize the result, I need to know the friction velocity(u_tau or u*).
when I use channelFoam, I can output the dpdx in each time, so from there I could calculate the friction velocity. but pisoFoam case, I have no idea.
So, I am wondering is there any utility to calculate friction velocity.
or equivalent properties. (i.e. u_tau^2 = dp/dx*h = tau_w/rho, where h is half depth of channel)
Thank you very much
Yusik
impecca is offline   Reply With Quote
Old   April 10, 2013, 10:09
Jakub Pola
stainboy is on a distinguished road
Hello Yusik,
I'm interested in this as well. Have you found some way to plot u_plus( y+) for channel flow?
Cheers,
Kuba.
stainboy is offline   Reply With Quote
Old   April 11, 2014, 01:33
CHARLES
CHARLES is on a distinguished road
This may be useful to obtain the values you need:
http://www.cfd-online.com/Forums/ope...-testcase.html
CHARLES is offline   Reply With Quote
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Problem with laminar 2d channel flow Quarkz Main CFD Forum 6 October 7, 2015 12:24
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
LES In Turbulent in channel flow pankaj saha Main CFD Forum 8 April 15, 2009 11:34
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
