Inclusion of density while calculating power
Old   May 29, 2014, 08:27
Default Inclusion of density while calculating power
Naruto is on a distinguished road
I am having a little confusion right now. In the source codes of incompressible flow solvers of OpenFOAM I have seen that, pressure quantity is divided with density rho beforehand in order to get dynamic pressure. Now my question is that, as rho is already used to get dynamic pressure- do I need to use density while calculating power co-efficient of turbo machinaries?
I mean by the definition of Cp = Power_Produced/ (0.5* projected area * density * velocity^3).
Now do I need to add density in this calculation?
Happy Foaming
Naruto is offline   Reply With Quote
Old   May 29, 2014, 11:49
Chris Sideroff
cnsidero is on a distinguished road
Yes as you need it to make Cp dimensionless and pressure is not used in the definition. However, because the flow is incompressible, it's simply a constant.
cnsidero is offline   Reply With Quote
Old   May 29, 2014, 11:56
Thanks for your reply.
But I think I have solved the problem. It is little bit puzzling. I would try to give a short explanation.
The attached is the force file from propeller tutorial. As you may see the rhoinfo has been kept 1. But if you give rhoinfo as 1000 or any other quantity the output would change.
However the best practice is to keep rhoinfo 1.
Thank you all.
Happy Foaming
Old   May 29, 2014, 12:57
Chris Sideroff
Attachment 31291
Thank you all.
No, you choose density, rhoInf, based on the fluid properties you're simulating and, if available, comparing to experiment. If you're working fluid is air at standard temperature and pressure, rhoInf ~ 1.2. If you're working fluid is water, rhoInf = 997. Your performance metrics should change with working fluids properties.
Old   June 9, 2014, 07:57
I am sorry to write again.
Assume I am calculating which needs density say power co-efficeint. If the input of rhoinf is 1. Then the calculation would be simply like:
Cp= Power produced/(0.5*Area*v^3).
But if the rhoinf is 1.25, then the Cp would be like:
Cp = Power produced/(0.5*1.25*Area*v^3).
Same thing could go for pressure co-efficient too.
Are my assumptions correct?
Happy Foaming
Old   June 10, 2014, 16:18
Chris Sideroff
Yes, that's correct
Power Spectral Density Madhusanka CFX 0 March 2, 2011 13:30
power spectral density vetnav Main CFD Forum 8 September 3, 2010 14:28
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Warning 097- AB Siemens 6 November 15, 2004 04:41
