June 18, 2014, 13:40
error - mesh.lookupObject<incompressible::LESModel>("LESPr operties");
Dear Foamers,
I'd like to access nuEff in a utility and use this code:
const incompressible::LESModel& model =
const volScalarField nuEff(model.nuEff());
const volScalarField nuLam(model.nu());
file constant/LESProperties:
LESModel dynamicSmagorinsky; //by Alberto Pasquale
delta cubeRootVol;
printCoeffs on;
file constant/turbulenceProperties:
simulationType LESModel;
turbulenceModel dynamicSmagorinsky;
turbulence on;
I use A. Pasquale's version of dynamicSmagorinsky already successfully in other cases. The lib is located in $FOAM_USER_LIBBIN.
If I try to run the utility for latestTime I receive this error ( already commented in another thread):
p, li { white-space: pre-wrap; } Time = 1000
Calculating wall distance
Writing wall distance to field y
Reading field U
Reading field WallShearStressLES
--> FOAM FATAL ERROR:
request for LESModel LESProperties from objectRegistry region0 failed
available objects of type LESModel are
0()
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/elisabeth/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
Foam::incompressible::LESModel const& Foam:bjectRegistry::lookupObject<Foam::incompres sible::LESModel>(Foam::word const&) const at ??:?
at ??:?
#4 __libc_start_main in "/lib64/libc.so.6"
at /home/abuild/rpmbuild/BUILD/glibc-2.18/csu/../sysdeps/x86_64/start.S:125
Das Programm ist abgestürzt.
/home/aylalisa/OpenFOAM/OpenFOAM-2.3.0/bin/foamExec ist abgestürzt
Can anybody help?
Best regards,
Aylalisa
