wallHeatFlux
Old   July 10, 2014, 07:26
Question wallHeatFlux
Michael
buck_s is on a distinguished road
Hello everyone,
I am currently using and modifying the wallHeatFlux utility in order to calculate other values, that are calculated from the heat flux. However, I am not quite sure how the utility calculates the heat flux... to be specific, I don't quite get this part:
surfaceScalarField heatFlux
            fvc::interpolate
                    turbulence.valid()
                  ? turbulence->alphaEff()()
                  : thermo->alpha()
            )*fvc::snGrad(h)
What are alpha and h in the code?
I am using OpenFOAM 2.2.x
I would really appreciate it, if someone could assist me with this by pointing out which equation is being used here to calculate q.
Thanks in advance.
buck_s is offline   Reply With Quote
Old   July 14, 2014, 05:18
Michael
Does anyone know how it works??
alpha, heat transfer, wallheatflux
wallHeatFlux and radiation craig.tickle OpenFOAM Post-Processing 5 December 2, 2018 08:00
Local heat transfer / modifying wallHeatFlux buck_s OpenFOAM Post-Processing 0 June 17, 2014 06:52
problem with WallHeatFlux Roman1 OpenFOAM Running, Solving & CFD 1 January 24, 2014 10:31
wallHeatFlux BC not constant after restart eelcovv OpenFOAM Running, Solving & CFD 26 May 24, 2011 23:11
[swak4Foam] groovyBC + wallHeatFlux BC prabhu OpenFOAM Community Contributions 1 July 21, 2009 10:56
